Clean Install
habuhejleh
Clean Install
Post by habuhejleh »
Dear ,
I have Nagios XI which was compromised and I managed to restrict the access to it.
Now I need to clear up the available Nagios on my server then do clean new installation.
Please advise asap.
Best regards,
Haitha
habuhejleh
Re: Clean Install
Dear All,
Please note that I inserted the script "./uninstall_xi.sh" into the nagios xi via WinSCP then I ran the command "./uninstall_xi.sh" it started the process but it failed as below:
Could not retrieve mirrorlist http://mirrorlist.centos.org/?release=6 ... 64&repo=os error was
14: PYCURL ERROR 7 - "Failed to connect to 2607:f8f8:700:12::10: Network is unreachable"
http://centos.mirror.iweb.ca/6/os/x86_6 ... repomd.xml: [Errno 14] PYCURL ERROR 7 - "Failed to connect to 2607:f748:10:12:0:ce17:705:1: Network is unreachable"
Trying other mirror.
http://mirror.as24220.net/pub/centos/6/ ... repomd.xml: [Errno 14] PYCURL ERROR 7 - "Failed to connect to 2402:d800:0:51::dead:beef: Network is unreachable"
Note that I opened in the firewall from external only
72.14.181.71 (assets.nagios.com) and 50.116.21.73 (api.nagios.com).
So why it is failing as above?
Should I open extra external IP's?
Is there away I can uninstall then install it manually through WinSCP?
Please advise asap.
cdienger
Re: Clean Install
Post by cdienger »
If a system has been compromised I would definitely go the route of at least reimaging the OS as well and then doing the clean install of XI.
habuhejleh
Re: Clean Install
Well, I opened external connection limited to:
72.14.181.71 (assets.nagios.com) and 50.116.21.73 (api.nagios.com) but the uninstall did not workout and gave error
What else I should open for external?
Please advise.
Re: Clean Install
This scripts uses "yum remove", e.g.
yum remove mysql postgresql -y
so you would need to have access to yum repos... Can you add/remove packages via yum or run "yum update" successfully?
habuhejleh
Re: Clean Install
No I cannot, I get this error:
[root@um-isp-nagios-redline ~]# yum update
Loaded plugins: fastestmirror, security
Loading mirror speeds from cached hostfile
Could not get metalink https://mirrors.fedoraproject.org/metal ... =epel-6&ar ch=x86_64 error was
14: PYCURL ERROR 7 - "Failed to connect to 2610:28:3090:3001:dead:beef:cafe:fed3 : Network is unreachable"
* base: centos.mirror.iweb.ca
* epel: epel.besthosting.ua
* extras: centos.mirror.iweb.ca
* updates: centos.mirror.iweb.ca
http://ftp.hosteurope.de/mirror/centos. ... repomd.xml: [Errno 14] PYCURL ERROR 7 - "Failed to connect to 2a01:488:10:1::50ed:888a: Network is unreachable"
http://ftp.jaist.ac.jp/pub/Linux/CentOS ... repomd.xml: [Errno 14] PYCURL ERROR 7 - "Failed to connect to 2001:df0:2ed:feed::feed: Network is unreachable"
http://mirror.centos.org/centos/6/os/x8 ... repomd.xml: [Errno 14] PYCURL ERROR 7 - "Failed to connect to 2c0f:f738:2201:e::: Network is unreachable"
http://mirror.us.leaseweb.net/centos/6/ ... repomd.xml: [Errno 14] PYCURL ERROR 7 - "Failed to connect to 2604:9a00:2010:a0b8::5: Network is unreachable"
http://mirrors.coreix.net/centos/6/os/x ... repomd.xml: [Errno 14] PYCURL ERROR 7 - "Failed to connect to 2a01:c0:2:3d::2: Network is unreachable"
Once again please advise what are the IP addresses I should open further??
And also can I update manually?
Re: Clean Install
Let step back for a moment. You are not able to run yum commands because you closed the Internet connection to your Nagios XI server. Opening a few IP addresses won't work as you re going to have some random IPs when accessing these mirrors... The best route to go would be what cdienger suggested:
Uninstalling Nagios XI won't guarantee that you are not going to have some malicious code left by the hackers somewhere else...
Once you start "fresh" with a clean system, you could do an "offline" install (if you wish).
https://repo.nagios.com/?repo=offline#install
