multiple errors on clients, new Red Hat nagios server.
jlamar
Post by jlamar »
New Server setup, Installing NSclient 0.5.2.3564 on clients. getting NSClient - ERROR: No performance data from command: check_"all services", and Unknown command(s): check_service
Re: multiple errors on clients, new Red Hat nagios server.
Can you post your nsclient.ini file from this folder on the Windows system?
C:\Program Files\NSClient++
There are probably some missing setting that have to be added to the file so we need to see it.
jlamar
Post by jlamar »
# If you want to fill this file with all avalible options run the following command:
# nscp settings --generate --add-defaults --load-all
# nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/settings/default]
; Undocumented key
password = nagiospass
; Undocumented key
allowed hosts = 127.0.0.1,10.1.1.221
[/modules]
; Undocumented key
CheckExternalScripts = disabled
; Undocumented key
CheckHelpers = disabled
; Undocumented key
CheckEventLog = disabled
; Undocumented key
CheckNSCP = disabled
; Undocumented key
CheckDisk = disabled
; Undocumented key
CheckSystem = disabled
; Undocumented key
NSClientServer = enabled
; Undocumented key
NRPEServer = enabled
; Undocumented key
NSCAClient = 1
[/settings/NRPE/server]
; Undocumented key
verify mode = none
; Undocumented key
insecure = true
Edit the nsclient.ini file and add the following to the bottom.
[/settings/NSClient/server]
performance data = 1
port = 12489
Then edit these options. Change them from
to
CheckHelpers = enabled
CheckDisk = enabled
CheckSystem = enabled
Save the file and restart NSClient++ on the Windows system and see if the errors are resolved on the Nagios server.
jlamar
Post by jlamar »
Perfect, Thank you.
I have one process not working for explorer.exe.
Unless someone is logged in to the Windows system's console or with RDP, explorer.exe will not be running and the output is correct.
jlamar
Post by jlamar »
ok, Thank you.
You can close ticket.
npolovenko
Post by npolovenko »
Closing the thread as resolved.
