has no service notification commands defined
Bitflogger
Post by Bitflogger »
Hello, I'm running v5.5.3 64-bit VM CentOS7
I'm getting the contact "has no service notification commands defined" for two contacts.
There very much do have notification commands defined. I tried the solution from case 48589, no luck.
There are over a hundred contacts that do not cause the error, I cannot find a difference between the problem and non-problem contacts.
We heavily use inheritance, the contact template for the problem contacts is the same as non-problem contacts.
Bitflogger
Re: has no service notification commands defined
I removed one of the problem contacts from its contact groups, then set the contact to NOT active.
The contact still comes up in the configuration error report!
Can you PM me (or anyone else on the Nagios Tech Support team) your latest profile? We need to review the configs of these contacts, and the commands, and templates in use.
Admin > System Profile > Download Profile
Bitflogger
I tried reconfigure_nagios.sh ,based on https://support.nagios.com/kb/article.php?id=532
I found an error due to a file in the import directory, for a host I has set to inactive.
I removed the file from the import directory, then it compiles. Please lock if no further questions.
This is a good trouble-shooting method.
[nagios@winston ~]$ cd /usr/local/nagiosxi/scripts
[nagios@winston scripts]$ cat /etc/hosts
127.0.0.1 localhost localhost.localdomain localhost4 localhost4.localdomain4
::1 localhost localhost.localdomain localhost6 localhost6.localdomain6
128.104.144.176 winston.doit.wisc.edu winston
[nagios@winston scripts]$ ./reconfigure_nagios.sh
--- reset_config_perms.sh ------------
> Setting CCM script permissions
> Setting script permissions
> Setting special component script permissions
> Setting configuration file/directory permissions
> Setting perfdata directory and RRD permissions
> Setting NOM checkpoint user:group permissions
> + Setting Nagios Core corelog.newobjects user:group permissions
> + Setting CCM configuration file user:group permissions
> + Setting Recurring Downtime file user:group permissions
> + Setting BPI configuration file user:group permissions
--- ccm_import.php -------------------
> Setting import directory: /usr/local/nagios/etc/import/
> Importing config files into the CCM
- Importing: /usr/local/nagios/etc/import/granato.doit.wisc.edu.cfg .. PHP Notice: Undefined index: host_name
in /usr/local/nagiosxi/html/includes/components/ccm/classes/import.class.php on line 551
PHP Notice: Undefined index: host_name in /usr/local/nagiosxi/html/includes/components/ccm/classes/import.class.php on line 905
PHP Notice: Undefined index: host_name in /usr/local/nagiosxi/html/includes/components/ccm/classes/import.class.php on line 551
ERROR
Duplicate entry '1' for key 'config_name'Entry host_name:: inside tbl_host could not be inserted: Duplicate entry '1' for key 'config_name'<br>Entry host_name:: inside tbl_host could not be inserted: Duplicate entry '1' for key 'config_name'<br>
Importing into the CCM failed!
No files to import
--- ccm_export.php -------------------
> Writing CCM configuration to Nagios files
Finished writing out configuraton
> Verifying configuration with Nagios Core
> Output:
Nagios Core 4.4.2
Last Modified: 2018-08-16
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for service 'w_service_automatic_and_disabled' on host 'ofr02.doit.wisc.edu' (config file '/usr/local/nagios/etc/services/w_service_automatic_and_disabled_2012.cfg', starting on line 16)
Checking objects...
Checked 15271 services.
Checked 901 hosts.
Checked 85 host groups.
Checked 6 service groups.
Warning: Contact 'tczerwon' has no service notification time period defined!
Warning: Contact 'tczerwon' has no host notification time period defined!
Checked 365 contacts.
Checked 422 contact groups.
Checked 250 commands.
Checked 103 time periods.
Checked 0 host escalations.
Checked 901 hosts
Checked 0 host dependencies
Checked 103 timeperiods
Checking misc settings...
Total Warnings: 2
Total Errors: 0
> Return Code: 0
I am glad your issue has been resolved! I am locking this topic.
