Hi. I noticed while troubleshooting a service check that the remote server has a hardcoded check_mem entry while there is also a configured service check for check_mem on the Nagios XI server using the parameters.
Which takes precedence? Is the service check configuration being ignored because there is a hardcoded checck_mem in ../etc/nrpe.cfg?
Thanks!
Service config or nrpe.cfg precedence order
Re: Service config or nrpe.cfg precedence order
You can call a command that has "hard-codeded" arguments:Which takes precedence? Is the service check configuration being ignored because there is a hardcoded checck_mem in ../etc/nrpe.cfg?
/usr/local/nagios/libexec/check_nrpe -H <ip address> -c <command>Code: Select all
/usr/local/nagios/libexec/check_nrpe -H <ip address> -c <command> -a '<arguments>'Be sure to check out our Knowledgebase for helpful articles and solutions!
Hi.
When I execute the check from the command line it works properly. When using the Nagios server to trigger via nrpe, it seems to report the values as though using the parameters in the nrpe.cfg file. The remote system is AIX 7.2.
Thanks!
Remote check_mem config
Execution from the command line
Run Check Command output with:
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
check_mem
-n -a '-u -C -w 80 -c 95'
Service Check Script
Thanks!
dalcbiwp30:/usr/local/nagios>grep check_mem ./etc/nrpe.cfg
command[check_mem]=/usr/local/nagios/libexec/check_mem -f -w 10 -c 5Code: Select all
/usr/local/nagios>./libexec/check_mem -u -C -w 80 -c 95
OK - 59.8% (59556540 kB) used.|TOTAL=99614720KB;;;; USED=59556540KB;79691776;94633984;; FREE=40058180KB;;;; CACHES=39136608KB;;;;
check_mem
/usr/local/nagios/libexec/check_nrpe -H 172.30.248.100 -t 30 -c check_mem -n -a '-u -C -w 80 -c 95'
CRITICAL - 0.6% (558220 kB) free!|TOTAL=99614720KB;;;; USED=99056500KB;89653248;94633984;; FREE=558220KB;;;; CACHES=38595600KB;;;;Code: Select all
#!/usr/bin/perl -w
# Heavily based on the script from:
# check_mem.pl Copyright (C) 2000 Dan Larsson <[email protected]>
# heavily modified by
# Justin Ellison <[email protected]>
# The MIT License (MIT)
# Copyright (c) 2011 [email protected]
# Permission is hereby granted, free of charge, to any person obtaining a copy of this
# software and associated documentation files (the "Software"), to deal in the Software
# without restriction, including without limitation the rights to use, copy, modify,
# merge, publish, distribute, sublicense, and/or sell copies of the Software, and to
# permit persons to whom the Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all copies
# or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
# INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR
# PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE
# FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT
# OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
# OTHER DEALINGS IN THE SOFTWARE.
# Tell Perl what we need to use
use strict;
use Getopt::Std;
#TODO - Convert to Nagios::Plugin
#TODO - Use an alarm
# Predefined exit codes for Nagios
use vars qw($opt_c $opt_f $opt_u $opt_w $opt_C $opt_v %exit_codes);
%exit_codes = ('UNKNOWN' , 3,
'OK' , 0,
'WARNING' , 1,
'CRITICAL', 2,
# Get our variables, do our checking:
init();
# Get the numbers:
my ($free_memory_kb,$used_memory_kb,$caches_kb) = get_memory_info();
print "$free_memory_kb Free\n$used_memory_kb Used\n$caches_kb Cache\n" if ($opt_v);
if ($opt_C) { #Do we count caches as free?
$used_memory_kb -= $caches_kb;
$free_memory_kb += $caches_kb;
# Round to the nearest KB
$free_memory_kb = sprintf('%d',$free_memory_kb);
$used_memory_kb = sprintf('%d',$used_memory_kb);
$caches_kb = sprintf('%d',$caches_kb);
# Tell Nagios what we came up with
tell_nagios($used_memory_kb,$free_memory_kb,$caches_kb);
sub tell_nagios {
my ($used,$free,$caches) = @_;
# Calculate Total Memory
my $total = $free + $used;
print "$total Total\n" if ($opt_v);
my $perf_warn;
my $perf_crit;
if ( $opt_u ) {
$perf_warn = int(${total} * $opt_w / 100);
$perf_crit = int(${total} * $opt_c / 100);
} else {
$perf_warn = int(${total} * ( 100 - $opt_w ) / 100);
$perf_crit = int(${total} * ( 100 - $opt_c ) / 100);
my $perfdata = "|TOTAL=${total}KB;;;; USED=${used}KB;${perf_warn};${perf_crit};; FREE=${free}KB;;;; CACHES=${caches}KB;;;;";
if ($opt_f) {
my $percent = sprintf "%.1f", ($free / $total * 100);
if ($percent <= $opt_c) {
finish("CRITICAL - $percent% ($free kB) free!$perfdata",$exit_codes{'CRITICAL'});
elsif ($percent <= $opt_w) {
finish("WARNING - $percent% ($free kB) free!$perfdata",$exit_codes{'WARNING'});
else {
finish("OK - $percent% ($free kB) free.$perfdata",$exit_codes{'OK'});
elsif ($opt_u) {
my $percent = sprintf "%.1f", ($used / $total * 100);
if ($percent >= $opt_c) {
finish("CRITICAL - $percent% ($used kB) used!$perfdata",$exit_codes{'CRITICAL'});
elsif ($percent >= $opt_w) {
finish("WARNING - $percent% ($used kB) used!$perfdata",$exit_codes{'WARNING'});
else {
finish("OK - $percent% ($used kB) used.$perfdata",$exit_codes{'OK'});
# Show usage
sub usage() {
print "\ncheck_mem.pl v1.0 - Nagios Plugin\n\n";
print "usage:\n";
print " check_mem.pl -<f|u> -w <warnlevel> -c <critlevel>\n\n";
print "options:\n";
print " -f Check FREE memory\n";
print " -u Check USED memory\n";
print " -C Count OS caches as FREE memory\n";
print " -w PERCENT Percent free/used when to warn\n";
print " -c PERCENT Percent free/used when critical\n";
print "\nCopyright (C) 2000 Dan Larsson <dl\@tyfon.net>\n";
print "check_mem.pl comes with absolutely NO WARRANTY either implied or explicit\n";
print "This program is licensed under the terms of the\n";
print "MIT License (check source code for details)\n";
exit $exit_codes{'UNKNOWN'};
sub get_memory_info {
my $used_memory_kb = 0;
my $free_memory_kb = 0;
my $total_memory_kb = 0;
my $caches_kb = 0;
my $uname;
if ( -e '/usr/bin/uname') {
$uname = `/usr/bin/uname -a`;
elsif ( -e '/bin/uname') {
$uname = `/bin/uname -a`;
else {
die "Unable to find uname in /usr/bin or /bin!\n";
print "uname returns $uname" if ($opt_v);
if ( $uname =~ /Linux/ ) {
my @meminfo = `/bin/cat /proc/meminfo`;
foreach (@meminfo) {
chomp;
if (/^Mem(Total|Free):\s+(\d+) kB/) {
my $counter_name = $1;
if ($counter_name eq 'Free') {
$free_memory_kb = $2;
elsif ($counter_name eq 'Total') {
$total_memory_kb = $2;
elsif (/^(Buffers|Cached|SReclaimable):\s+(\d+) kB/) {
$caches_kb += $2;
$used_memory_kb = $total_memory_kb - $free_memory_kb;
elsif ( $uname =~ /HP-UX/ ) {
# HP-UX, thanks to Christoph Fürstaller
my @meminfo = `/usr/bin/sudo /usr/local/bin/kmeminfo`;
chomp;
if (/^Physical memory\s\s+=\s+(\d+)\s+(\d+.\d)g/) {
$total_memory_kb = ($2 * 1024 * 1024);
elsif (/^Free memory\s\s+=\s+(\d+)\s+(\d+.\d)g/) {
$free_memory_kb = ($2 * 1024 * 1024);
elsif ( $uname =~ /FreeBSD/ ) {
# The FreeBSD case. 2013-03-19 www.claudiokuenzler.com
# free mem = Inactive*Page Size + Cache*Page Size + Free*Page Size
my $pagesize = `sysctl vm.stats.vm.v_page_size`;
$pagesize =~ s/[^0-9]//g;
my $mem_inactive = 0;
my $mem_cache = 0;
my $mem_free = 0;
my $mem_total = 0;
my $free_memory = 0;
my @meminfo = `/sbin/sysctl vm.stats.vm`;
chomp;
if (/^vm.stats.vm.v_inactive_count:\s+(\d+)/) {
$mem_inactive = ($1 * $pagesize);
elsif (/^vm.stats.vm.v_cache_count:\s+(\d+)/) {
$mem_cache = ($1 * $pagesize);
elsif (/^vm.stats.vm.v_free_count:\s+(\d+)/) {
$mem_free = ($1 * $pagesize);
elsif (/^vm.stats.vm.v_page_count:\s+(\d+)/) {
$mem_total = ($1 * $pagesize);
$free_memory = $mem_inactive + $mem_cache + $mem_free;
$free_memory_kb = ( $free_memory / 1024);
$total_memory_kb = ( $mem_total / 1024);
$caches_kb = ($mem_cache / 1024);
elsif ( $uname =~ /joyent/ ) {
# The SmartOS case. 2014-01-10 www.claudiokuenzler.com
# free mem = pagesfree * pagesize
my $pagesize = `pagesize`;
my $phys_pages = `kstat -p unix:0:system_pages:pagestotal | awk '{print \$NF}'`;
my $free_pages = `kstat -p unix:0:system_pages:pagesfree | awk '{print \$NF}'`;
my $arc_size = `kstat -p zfs:0:arcstats:size | awk '{print \$NF}'`;
my $arc_size_kb = $arc_size / 1024;
print "Pagesize is $pagesize" if ($opt_v);
print "Total pages is $phys_pages" if ($opt_v);
print "Free pages is $free_pages" if ($opt_v);
print "Arc size is $arc_size" if ($opt_v);
$caches_kb += $arc_size_kb;
$total_memory_kb = $phys_pages * $pagesize / 1024;
$free_memory_kb = $free_pages * $pagesize / 1024;
elsif ( $uname =~ /SunOS/ ) {
eval "use Sun::Solaris::Kstat";
if ($@) { #Kstat not available
if ($opt_C) {
print "You can't report on Solaris caches without Sun::Solaris::Kstat available!\n";
exit $exit_codes{UNKNOWN};
my @vmstat = `/usr/bin/vmstat 1 2`;
my $line;
foreach (@vmstat) {
chomp;
$line = $_;
$free_memory_kb = (split(/ /,$line))[5] / 1024;
my @prtconf = `/usr/sbin/prtconf`;
foreach (@prtconf) {
if (/^Memory size: (\d+) Megabytes/) {
$total_memory_kb = $1 * 1024;
else { # We have kstat
my $kstat = Sun::Solaris::Kstat->new();
my $phys_pages = ${kstat}->{unix}->{0}->{system_pages}->{physmem};
my $free_pages = ${kstat}->{unix}->{0}->{system_pages}->{freemem};
# We probably should account for UFS caching here, but it's unclear
# to me how to determine UFS's cache size. There's inode_cache,
# and maybe the physmem variable in the system_pages module??
# In the real world, it looks to be so small as not to really matter,
# so we don't grab it. If someone can give me code that does this,
# I'd be glad to put it in.
my $arc_size = (exists ${kstat}->{zfs} && ${kstat}->{zfs}->{0}->{arcstats}->{size}) ?
${kstat}->{zfs}->{0}->{arcstats}->{size} / 1024
: 0;
$caches_kb += $arc_size;
elsif ( $uname =~ /AIX/ ) {
my @meminfo = `/usr/bin/vmstat -vh`;
chomp;
if (/^\s*([0-9.]+)\s+(.*)/) {
my $counter_name = $2;
if ($counter_name eq 'memory pages') {
$total_memory_kb = $1*4;
if ($counter_name eq 'free pages') {
$free_memory_kb = $1*4;
if ($counter_name eq 'file pages') {
$caches_kb = $1*4;
if ($counter_name eq 'Number of 4k page frames loaned') {
$free_memory_kb += $1*4;
else {
if ($opt_C) {
print "You can't report on $uname caches!\n";
my $command_line = `vmstat | tail -1 | awk '{print \$4,\$5}'`;
chomp $command_line;
my @memlist = split(/ /, $command_line);
# Define the calculating scalars
$used_memory_kb = $memlist[0]/1024;
$free_memory_kb = $memlist[1]/1024;
$total_memory_kb = $used_memory_kb + $free_memory_kb;
return ($free_memory_kb,$used_memory_kb,$caches_kb);
sub init {
# Get the options
if ($#ARGV le 0) {
&usage;
else {
getopts('c:fuCvw:');
# Shortcircuit the switches
if (!$opt_w or $opt_w == 0 or !$opt_c or $opt_c == 0) {
print "*** You must define WARN and CRITICAL levels!\n";
&usage;
elsif (!$opt_f and !$opt_u) {
print "*** You must select to monitor either USED or FREE memory!\n";
&usage;
# Check if levels are sane
if ($opt_w <= $opt_c and $opt_f) {
print "*** WARN level must not be less than CRITICAL when checking FREE memory!\n";
&usage;
elsif ($opt_w >= $opt_c and $opt_u) {
print "*** WARN level must not be greater than CRITICAL when checking USED memory!\n";
&usage;
sub finish {
my ($msg,$state) = @_;
print "$msg\n";
exit $state;
The arguments in your command are "hard-coded":
Make sure you have the following line in the nrpe.cfg file:
Save, exit, and restart NRPE.
Test your command again.
Is it working now?
Note: As an alternative, if you didn't want to pass the arguments in your check (on the Nagios XI server), you could have them hard-coded (on the client).
Example command on the remote box:
Example check on the Nagios XI server:
It seems like you don't want to check the "FREE" memory but the "USED" memory (according to your check, run on the Nagios XI server).command[check_mem]=/usr/local/nagios/libexec/check_mem -f -w 10 -c 5
Change the check_mem command on the remote box to look like this:/usr/local/nagios/libexec/check_nrpe -H 172.30.248.100 -t 30 -c check_mem -n -a '-u -C -w 80 -c 95'
command[check_mem]=/usr/local/nagios/libexec/check_mem $ARG1$Code: Select all
dont_blame_nrpe=1Test your command again.
/usr/local/nagios/libexec/check_nrpe -H 172.30.248.100 -t 30 -c check_mem -n -a '-u -C -w 80 -c 95'Note: As an alternative, if you didn't want to pass the arguments in your check (on the Nagios XI server), you could have them hard-coded (on the client).
command[check_mem]=/usr/local/nagios/libexec/check_mem -u -C -w 80 -c 95Code: Select all
/usr/local/nagios/libexec/check_nrpe -H 172.30.248.100 -t 30 -c check_memBe sure to check out our Knowledgebase for helpful articles and solutions!
Thank you for th3e explanation. The service check is working properly now.
We can close this one.
//cheers
//cheers
I am glad I was able to help!
