Hi
I have question about Nagvis map on Nagios xi, Are there limitation for number of creation custom maps on nagvis?
I need more than 150 maps on it.
Nagvis Map
benjaminsmith
Re: Nagvis Map
Hi @Parisa
I took a look at the configuration file for Nagvis, and there isn't a setting limiting the number of maps. When you load the NagVis page, it will take longer to load the Map Index.Are there limitation for number of creation custom maps on nagvis?
Re: Nagvis Map
Thanks for your answer @benjaminsmith
I had checked it already but didn't find any limitation. I needed to make sure because I have more than 150 maps but the maps will use sometimes not always.
benjaminsmith
Re: Nagvis Map
HI @parisa
Ok. Let me know if it's ok to close this post. Thank you.Thanks for your answer @benjaminsmith
