I have set up a windows server 2012 with NSClient. All works well for check_nt however when adding a monitor to check the disk i/o using nrpe I am receiving UNKNOWN: No Handler For That Command.
[nagios@am1nms-nagiosxi ~]$ /usr/local/nagios/libexec/check_nrpe -H haa-sim-PayGW1-p_w-itops -t 30 -c check_ms_win_disk_load
UNKNOWN: No handler for that command
I have spent some time going through the ini file but can't get it to work. Can you shed some light on why I have this error being returned?
I have attached the ini file for your perusal.
Thanks in advance.
