check_ms_iis_application_pool powershell auth issue
jkelly1959
Post by jkelly1959 »
Our standard powershell execution policy setting is Restricted
Setting the policy to unrestricted does NOT help.
Here is error that we get when unrestricted.
check failed.
At line:1 char:1
+ scripts/powershell/check_ms_iis_application_pool.ps1 -A Diamond; exit ...
+ CategoryInfo : SecurityError: (:) [], PSSecurityException
+ FullyQualifiedErrorId : UnauthorizedAccess
I have been able to get it to run setting the policy on the windows server to bypass. However we really dont want to do that on the windows server.
I have tried to add the switch -ExecutionPolicy to bypass in the wrappings of the nsclient ini file but not having luck there or sure I am doing it right. I will attach nsclient ini.
I have been able to get this plugin to work when I set the server execution policy to Bypass.
Any suggestions on how to get this to run?
John
ssax
Dreams In Code
Re: check_ms_iis_application_pool powershell auth issue
Post by ssax »
Please change your last line to this:
check_ms_iis_application_pool=cmd /c echo scripts/powershell/check_ms_iis_application_pool.ps1 $ARG1$; exit $LastExitCode | powershell.exe /noprofile -ExecutionPolicy Bypass -command -
Then restart the NSClient++ service and test again.
Thank you
jkelly1959
Don't I feel silly....Than Worked!
Thank you
