Nagios OK notification before Critical
atsb
Post by atsb »
Hello!
About nagios XI environment
1) Linux Distribution and version? Centos7
2) 32 or 64bit? 64bit
3) VMware Image or Manual Install of XI? Manual install
4) Are there special configurations on your system, ie; is Gnome installed? Are you using a proxy? Are you using SSL? SSL
5) NagiosXI version: 5.5.5
I have a case where i got OK notification without getting any Critical notification before, which is not how it supposed to work:
That service notification settings:
cdienger
Re: Nagios OK notification before Critical
Post by cdienger »
I haven't been able to reproduce this yet. Are you able to reproduce it at will? How frequently are you seeing this if not? Can you provide a screenshot showing the rest of the check's config including check interval?
Check the version of core with "/usr/local/nagios/bin/nagios --version"
atsb
Post by atsb »
Hello!
I havent noticed it myself before and also i am not able to reproduce this kind of behavior.
Rest of the check config:
Nagios Core version 4.4.2
I understand that this can also be considered as anomaly.
Are you still experiencing this issue? I would recommend that you open a support ticket via our Support Center as soon as the issue resurfaces.
atsb
Post by atsb »
I experienced it again with different service - no critical state notification and then suddenly OK state notification:
Service details
I also opened support ticket.
Edit: I also want to note that these both are BPI services, if it makes any difference.
ssax
Dreams In Code
Post by ssax »
Locking thread, ticket received, we will continue support through the ticket.
