Are you receiving any errors? If so, can you post them here?
Have to compared the settings in the nsclient.ini file between a working server and a non working server to see if the configurations are the same?
Can you post the full nsclient.ini file from a non working server so we can view it?
# If you want to fill this file with all avalible options run the following command:
# nscp settings --generate --add-defaults --load-all
# nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/settings/default]
; Undocumented key
password = password
; Undocumented key
allowed hosts = 10.2.8.79,127.0.0.1
; CACHE ALLOWED HOSTS - If host names (DNS entries) should be cached, improves speed and security somewhat but won't allow you to have dynamic IPs for your Nagios server.
cache allowed hosts = 1
; TIMEOUT - Timeout when reading packets on incoming sockets. If the data has not arrived within this time we will bail out.
timeout = 30
; INBOX - The default channel to post incoming messages on
inbox = inbox
[/settings/NRPE/server]
; Undocumented key
verify mode = none
; Undocumented key
insecure = true
; ENABLE SSL ENCRYPTION - This option controls if SSL should be enabled.
;use ssl = 1
; COMMAND ALLOW NASTY META CHARS - This option determines whether or not the we will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow nasty characters = 1
; COMMAND ARGUMENT PROCESSING - This option determines whether or not the we will allow clients to specify arguments to commands that are executed.
allow arguments = 1
; PORT NUMBER - Port to use for NRPE.
port = 5666
; EXTENDED RESPONSE - Send more then 1 return packet to allow response to go beyond payload size (requires modified client if legacy is true this defaults to false).
extended response = 1
[/modules]
; Undocumented key
CheckExternalScripts = 1
; Undocumented key
CheckHelpers = 1
; Undocumented key
CheckNSCP = 1
; Undocumented key
CheckDisk = 1
; Undocumented key
CheckSystem = 1
; Undocumented key
NSClientServer = 1
; Undocumented key
CheckEventLog = 1
; Undocumented key
NSCAClient = 1
; Undocumented key
NRPEServer = 1
; SimpleFileWriter - Write status updates to a text file (A bit like the NSCA server does)
SimpleFileWriter = 0
; PythonScript - Loads and processes internal Python scripts
PythonScript = 0
; NRDPClient - NRDP client can be used both from command line and from queries to check remote systes via NRDP
NRDPClient = 0
; DotnetPlugin - Plugin to load and manage plugins written in dot net.
DotnetPlugins = 0
; CommandClient - A command line client, generally not used except with "nscp test".
CommandClient = 0
; CheckTaskSched - Check status of your scheduled jobs.
CheckTaskSched = 0
; NSCAServer - A server that listens for incoming NSCA connection and processes incoming requests.
NSCAServer = 0
; CheckLogFile - File for checking log files and various other forms of updating text files
CheckLogFile = 0
; SyslogClient - Forward information as syslog messages to a syslog server
SyslogClient = 0
; Scheduler - Use this to schedule check commands and jobs in conjunction with for instance passive monitoring through NSCA
Scheduler = 0
; NRPEClient - NRPE client can be used both from command line and from queries to check remote systes via NRPE as well as configure the NRPE server
NRPEClient = 0
; WEBServer - A server that listens for incoming HTTP connection and processes incoming requests. It provides both a WEB UI as well as a REST API in addition to simplifying configuration of WEB Server module.
WEBServer = 1
; GraphiteClient - Graphite client can be used to submit graph data to a graphite graphing system
GraphiteClient = 0
; SMTPClient - SMTP client can be used both from command line and from queries to check remote systes via SMTP
SMTPClient = 0
; CheckWMI - Check status via WMI
CheckWMI = 0
; SimpleCache - Stores status updates and allows for active checks to retrieve them
SimpleCache = 0
; A list of available remote target systems
[/settings/targets]
; Configure which services has to be in which state
[/settings/system/windows/service mapping]
; A set of options to configure the real time checks
[/settings/system/windows/real-time]
; Section for system checks and system settings
[/settings/system/windows]
; DEFAULT LENGTH - Used to define the default interval for range buffer checks (ie. CPU).
default buffer length = 1h
; Section for configuring the shared session.
[/settings/shared session]
; ENABLE THE SAHRED SESSION - This is currently not added in 0.4.x
enabled = false
; Section for the PythonScripts module.
[/settings/python]
[/settings/logfile/real-time]
; REAL TIME CHECKING - Spawns a background thread which waits for file changes.
enabled = 0
; Configure log file properties.
[/settings/log/file]
; MAXIMUM FILE SIZE - When file size reaches this it will be truncated to 50% if set to 0 (default) truncation will be disabled
max size = 0
; A list of scripts available to run from the PythonScript module.
[/settings/python/scripts]
; Section for configuring the log handling.
[/settings/log]
; LOG LEVEL - Log level to use. Available levels are error,warning,info,debug,trace
level = info
; FILENAME - The file to write log data to. Set this to none to disable log to file.
file name = ${exe-path}/nsclient.log
; DATEMASK - The size of the buffer to use when getting messages this affects the speed and maximum size of messages you can recieve.
date format = %Y-%m-%d %H:%M:%S
; Section for simple file writer module (SimpleFileWriter.dll).
[/settings/writers/file]
; MESSAGE SYNTAX - The syntax of the message to write to the line. Can be any arbitrary string as well as include any of the following special keywords:${command} = The command name, ${host} the host, ${channel} the recieving channel, ${alias} the alias for the command, ${alias-or-command} = alias if set otherweise command, ${message} = the message data (no escape), ${result} = The result status (number).
syntax = ${alias-or-command} ${result} ${message}
; FILE TO WRITE TO - The filename to write output to.
file = output.txt
; CHANNEL - The channel to listen to.
channel = FILE
; Section for graphite passive check module.
[/settings/graphite/client]
channel = GRAPHITE
; HOSTNAME - The host name of this host if set to blank (default) the windows name of the computer will be used.
hostname = auto
; A list of wrapped scripts (ie. scruts using a template mechanism). The template used will be defined by the extension of the script.
; Target definition for: default
[/settings/syslog/client/targets/default]
; TODO -
warning severity = warning
; TODO -
tag_syntax = NSCA
; TODO -
severity = error
; TODO -
ok severity = informational
; TODO -
message_syntax = %message%
; TODO -
facility = kernel
; TODO -
critical severity = critical
; TODO -
unknown severity = emergency
; Section for external scripts configuration options (CheckExternalScripts).
[/settings/external scripts]
; COMMAND TIMEOUT - The maximum time in seconds that a command can execute. (if more then this execution will be aborted). NOTICE this only affects external commands not internal ones.
timeout = 60
; allow nasty characters = 0
allow arguments = 1
; Section for SYSLOG passive check module.
[/settings/syslog/client]
channel = syslog
[/settings/eventlog/real-time]
; STARTUP AGE - The initial age to scan when starting NSClient++
startup age = 30m
; REAL TIME CHECKING - Spawns a background thread which detects issues and reports them back instantly.
enabled = 0
; LOGS TO CHECK - Comma separated list of logs to check
log = application,system
; DEBUG - Log missed records (useful to detect issues with filters) not useful in production as it is a bit of a resource hog.
debug = 0
; Section for configuring the crash handler.
[/settings/crash]
; CRASH ARCHIVE LOCATION - The folder to archive crash dumps in
archive folder = ${shared-path}/crash-dumps
; RESTART SERVICE NAME - The url to submit crash reports to
restart target = NSCP
; SUBMISSION URL - The url to submit crash reports to
submit url = https://crash.nsclient.org/post
; RESTART - Submit crash reports to nsclient.org (or your configured submission server)
restart = true
; ARCHIVE CRASHREPORTS - Archive crash reports in the archive folder
archive = true
; SUBMIT CRASHREPORTS - Submit crash reports to nsclient.org (or your configured submission server)
submit = false
; Section for log file checker
[/settings/logfile]
; Section for SMTP passive check module.
[/settings/SMTP/client]
channel = SMTP
; Section for NSCA (NSCAServer) (check_nsca) protocol options.
[/settings/NSCA/server]
; PORT NUMBER - Port to use for NSCA.
port = 5667
; PERFORMANCE DATA - Send performance data back to nagios (set this to false to remove all performance data).
performance data = 1
use ssl = 0
; ENCRYPTION - Name of encryption algorithm to use. Has to be the same as your agent i using or it wont work at all.This is also independent of SSL and generally used instead of SSL. Available encryption algorithms are: none = No Encryption (not safe) xor = XOR des = DES 3des = DES-EDE3 cast128 = CAST-128 xtea = XTEA blowfish = Blowfish twofish = Twofish rc2 = RC2 aes128 = AES aes192 = AES aes = AES serpent = Serpent gost = GOST
encryption = aes
; PAYLOAD LENGTH - Length of payload to/from the NSCA agent. This is a hard specific value so you have to "configure" (read recompile) your NSCA agent to use the same value for it to work.
payload length = 512
[/settings/NSCA/client/targets/default]
use ssl = 0
; TIMEOUT - Timeout when reading/writing packets to/from sockets.
timeout = 30
; ENCRYPTION - Name of encryption algorithm to use. Has to be the same as your server i using or it wont work at all.This is also independent of SSL and generally used instead of SSL. Available encryption algorithms are: none = No Encryption (not safe) xor = XOR des = DES 3des = DES-EDE3 cast128 = CAST-128 xtea = XTEA blowfish = Blowfish twofish = Twofish rc2 = RC2 aes128 = AES aes192 = AES aes = AES serpent = Serpent gost = GOST
encryption = aes
; ALLOWED CIPHERS - A better value is: ALL:!ADH:!LOW:!EXP:!MD5:@STRENGTH
allowed ciphers = ADH
; VERIFY MODE -
verify mode = none
; Section for NSClient (NSClientServer.dll) (check_nt) protocol options.
[/settings/NSClient/server]
use ssl = 0
; PERFORMANCE DATA - Send performance data back to Nagios (set this to 0 to remove all performance data).
; PORT NUMBER - Port to use for check_nt.
port = 12489
; A set of filters to use in real-time mode
[/settings/system/windows/real-time/checks]
; Section for NSCA passive check module.
[/settings/NSCA/client]
; HOSTNAME - The host name of the monitored computer. Set this to auto (default) to use the windows name of the computer. auto Hostname ${host} Hostname ${host_lc} Hostname in lowercase ${host_uc} Hostname in uppercase ${domain} Domainname ${domain_lc} Domainname in lowercase ${domain_uc} Domainname in uppercase
hostname = auto
channel = NSCA
[/settings/NRDP/client/targets/default]
; SENDER - Sender of email message
sender = nscp@localhost
; RECIPIENT - Recipient of email message
recipient = nscp@localhost
; TEMPLATE - Template for message data
template = Hello, this is %source% reporting %message%!
timeout = 30
[/settings/NRDP/client]
hostname = auto
channel = NRDP
[/settings/NRPE/client/targets/default]
; VERIFY MODE - What to verify default is non, to validate remote certificate use remote-peer
verify mode = none
; PAYLOAD LENGTH - Length of payload to/from the NRPE agent. This is a hard specific value so you have to "configure" (read recompile) your NRPE agent to use the same value for it to work.
payload length = 1024
use ssl = 1
timeout = 30
; Section for WEB (WEBServer.dll) (check_WEB) protocol options.
[/settings/WEB/server]
; PORT NUMBER - Port to use for WEB server.
port = 8443s
; CERTIFICATE - Ssl certificate to use for the ssl server
certificate = ${certificate-path}/certificate.pem
[/settings/SMTP/client/targets/default]
timeout = 30
; Files to be included in the configuration
[/includes]
; Section for the EventLog Checker (CheckEventLog.dll).
[/settings/eventlog]
; BUFFER_SIZE - The size of the buffer to use when getting messages this affects the speed and maximum size of messages you can recieve.
buffer size = 131072
; LOOKUP NAMES - Lookup the names of eventlog files
lookup names = 1
; DEBUG - Log more information when filtering (useful to detect issues with filters) not useful in production as it is a bit of a resource hog.
debug = 0
; Section for NRPE active/passive check module.
[/settings/NRPE/client]
channel = NRPE
; Section for the Scheduler module.
[/settings/scheduler/schedules]
; A list of scripts available to run from the CheckExternalScripts module. Syntax is: <command>=<script> <arguments>
; Check Windows Temp Folder
check_winfile = scripts\\check_winfile.exe $ARG1$ $ARG2$ $ARG3$
; Check Windows Updates
#Check_Updates = cscript.exe //T:30 //NoLogo scripts\\nm-check-available-updates.vbs
check_updates=cmd /c echo scripts\check_windows_updates.ps1 $ARG1$ $ARG2$; exit $LastExitCode | powershell.exe -command -
; Check Windows Explorer
check_explorer = scripts\\check_winprocess.exe $ARG1$ $ARG2$ $ARG3$
; A list of aliases available.
;An alias is an internal command that has been predefined to provide a single command without arguments. Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop)
[/settings/external scripts/alias]
; alias_sched_all - Alias for alias_sched_all. To configure this item add a section called: /settings/external scripts/alias/alias_sched_all
alias_sched_all = check_tasksched show-all "syntax=${title}: ${exit_code}" "crit=exit_code ne 0"
; alias_file_size - Alias for alias_file_size. To configure this item add a section called: /settings/external scripts/alias/alias_file_size
alias_file_size = check_files "path=$ARG1$" "crit=size > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${size}" max-dir-depth=10
; alias_process_hung - Alias for alias_process_hung. To configure this item add a section called: /settings/external scripts/alias/alias_process_hung
alias_process_hung = check_process "filter=is_hung" "crit=count>0"
; alias_process - Alias for alias_process. To configure this item add a section called: /settings/external scripts/alias/alias_process
alias_process = check_process "process=$ARG1$" "crit=state != 'started'"
; alias_service_ex - Alias for alias_service_ex. To configure this item add a section called: /settings/external scripts/alias/alias_service_ex
alias_service_ex = check_service "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
; alias_event_log - Alias for alias_event_log. To configure this item add a section called: /settings/external scripts/alias/alias_event_log
alias_event_log = check_eventlog
; alias_volumes_loose - Alias for alias_volumes_loose. To configure this item add a section called: /settings/external scripts/alias/alias_volumes_loose
alias_volumes_loose = check_drivesize
; alias_volumes - Alias for alias_volumes. To configure this item add a section called: /settings/external scripts/alias/alias_volumes
alias_volumes = check_drivesize
; alias_disk - Alias for alias_disk. To configure this item add a section called: /settings/external scripts/alias/alias_disk
alias_disk = check_drivesize
; alias_up - Alias for alias_up. To configure this item add a section called: /settings/external scripts/alias/alias_up
alias_up = check_uptime
; alias_cpu_ex - Alias for alias_cpu_ex. To configure this item add a section called: /settings/external scripts/alias/alias_cpu_ex
alias_cpu_ex = check_cpu "warn=load > $ARG1$" "crit=load > $ARG2$" time=5m time=1m time=30s
; alias_file_age - Alias for alias_file_age. To configure this item add a section called: /settings/external scripts/alias/alias_file_age
alias_file_age = check_files "path=$ARG1$" "crit=written > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${written}" max-dir-depth=10
; alias_process_stopped - Alias for alias_process_stopped. To configure this item add a section called: /settings/external scripts/alias/alias_process_stopped
alias_process_stopped = check_process "process=$ARG1$" "crit=state != 'stopped'"
; alias_service - Alias for alias_service. To configure this item add a section called: /settings/external scripts/alias/alias_service
alias_service = check_service
; alias_cpu - Alias for alias_cpu. To configure this item add a section called: /settings/external scripts/alias/alias_cpu
alias_cpu = check_cpu
; alias_mem - Alias for alias_mem. To configure this item add a section called: /settings/external scripts/alias/alias_mem
alias_mem = check_memory
; alias_process_count - Alias for alias_process_count. To configure this item add a section called: /settings/external scripts/alias/alias_process_count
alias_process_count = check_process "process=$ARG1$" "warn=count > $ARG2$" "crit=count > $ARG3$"
; alias_sched_task - Alias for alias_sched_task. To configure this item add a section called: /settings/external scripts/alias/alias_sched_task
alias_sched_task = check_tasksched show-all "filter=title eq '$ARG1$'" "detail-syntax=${title} (${exit_code})" "crit=exit_code ne 0"
; alias_disk_loose - Alias for alias_disk_loose. To configure this item add a section called: /settings/external scripts/alias/alias_disk_loose
alias_disk_loose = check_drivesize
; alias_sched_long - Alias for alias_sched_long. To configure this item add a section called: /settings/external scripts/alias/alias_sched_long
alias_sched_long = check_tasksched "filter=status = 'running'" "detail-syntax=${title} (${most_recent_run_time})" "crit=most_recent_run_time < -$ARG1$"
[/settings/graphite/client/targets/default]
; PATH FOR VALUES - Path mapping for metrics
path = system.${hostname}.${check_alias}.${perf_alias}
; Modules written in dotnet/CLR
[/modules/dotnet]
; Add counters to check
[/settings/system/windows/counters]
[/settings/logfile/real-time/checks]
; Section for simple cache module (SimpleCache.dll).
[/settings/cache]
channel = CACHE
; PRIMARY CACHE INDEX - Set this to the value you want to use as unique key for the cache. Can be any arbitrary string as well as include any of the following special keywords:${command} = The command name, ${host} the host, ${channel} the recieving channel, ${alias} the alias for the command, ${alias-or-command} = alias if set otherweise command, ${message} = the message data (no escape), ${result} = The result status (number).
primary index = ${alias-or-command}
[/settings/scheduler]
; THREAD COUNT - Number of threads to use.
threads = 5
; A list of templates for wrapped scripts.
;%SCRIPT% will be replaced by the actual script an %ARGS% will be replaced by any given arguments.
[/settings/external scripts/wrappings]
; BATCH FILE WRAPPING -
bat = scripts\\%SCRIPT% %ARGS%
; VISUAL BASIC WRAPPING -
vbs = cscript.exe //T:30 //NoLogo scripts\\lib\\wrapper.vbs %SCRIPT% %ARGS%
; POWERSHELL WRAPPING -
ps1 = cmd /c echo scripts\\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
[/settings/eventlog/real-time/filters]
[/paths]
; Path for shared-path -
shared-path = C:\Program Files\NSClient++
; Path for exe-path -
exe-path = C:\Program Files\NSClient++
; Path for crash-folder -
crash-folder = C:\Program Files\NSClient++
; Path for certificate-path -
certificate-path = ${shared-path}/security
; Path for base-path -
base-path = C:\Program Files\NSClient++
; Path for module-path -
module-path = ${shared-path}/modules
Glad the change is working for you now.
If you want to post your settings for the .proto files, you can post it on the Exchange site at the following link. https://exchange.nagios.org/
