PHP warnings
Bitflogger
PHP warnings
Post by Bitflogger »
Hello, I'm running v5.5.3, 64 bit, VM, CentOs 7.
I see a number of warnings in /var/log/http/ssl_error_log like this:
[Mon Oct 22 16:52:50.112284 2018] [:error] [pid 2244] [client 144.92.108.187:58090] PHP Notice: Undefined index: idMaster in /usr/local/nagiosxi/html/includes/components/ccm/classes/data.class.php on line 1593, referer: https://nagiosxi.doit.wisc.edu/nagiosxi ... 26page%3D1
Are the warnings significant? Can they be fixed?
Earl
npolovenko
Re: PHP warnings
Post by npolovenko »
Hello, @Bitflogger. Most often these warnings are caused by using unassigned variables in php. It is safe to ignore warnings.
You can stop these messages by changing the parameter in the /etc/php.ini file. Please open it and change the following line:
error_reporting = E_ALL & ~E_DEPRECATED & ~E_STRICT
to
error_reporting = E_ALL & ~E_DEPRECATED & ~E_STRICT & ~E_WARNING
Then run:
service httpd restart
Bitflogger
Re: PHP warnings
This is done, please lock the case.
Earl
