I am working on nagios core. I have one custom API for notification. I have configured nagios core for sending email to user whenever there is any warning or critical situation. I need to send this email details to my custom notification API.
Is there any way?
Thank you.
How to send Nagios data to any custom API
Re: How to send Nagios data to any custom API
You can create a nagios command that calls your script that interacts with the custom API just like the existing notification commands.
Then create a contact and assign those notification commands to the user.
Add the contact to all the objects you want to send the custom notifications for.
A Twilio implementation I did:
https://support.nagios.com/forum/viewto ... 38#p263738
Thanks for sharing @mcapra!mcapra wrote:A Twilio implementation I did:
