View host cpu/ram/hdd usage graph on one page?!
xpertech
Post by xpertech »
Can I setup to view host's cpu/ram/hdd usage graph on one single page?!
npolovenko
Re: View host cpu/ram/hdd usage graph on one page?!
Post by npolovenko »
Hello, @xpertech . You could add all these graphs to one dashboard.
You could also merge graphs into one using the Multi-stacked performance graph. Graph Explorer(in the left column), then click on the "multi-stacked performance graphs" tab. You can also deploy a multi-stacked graph to a dashboard by clicking on a blue icon in the top left corner.
