how to add multiple file sources to the config file?
dlukinski
Post by dlukinski »
Hello
How to add multiple file sources to the config file?
<Input windowsfile2>
Module im_file
File 'C:\Program Files (x86)\Folder1\Folder2\pgsql\data\pg_log' - say I have few more LOG files to add?
SavePos TRUE
# ReadFromLast FALSE
Exec $Message = $raw_event;
</Input>
Thank you
dlukinski
Re: how to add multiple file sources to the config file?
Post by dlukinski »
dlukinski wrote:Hello
<Input windowsfile>
Module im_file
SavePos TRUE
</Input>
Thank you
I guess it would have to be :
<Input windowsfile2> - File # 2
Module im_file
File 'C:\Program Files (x86)\Folder1\Folder2\pgsql\data\pg_log2'
SavePos TRUE
</Input>
cdienger
Post by cdienger »
It looks like the wildcard in a filename is supported as well:
https://nxlog.co/docs/nxlog-ce/nxlog-re ... onfig_file
dlukinski
Post by dlukinski »
cdienger wrote:It looks like the wildcard in a filename is supported as well:
Thank you
Please close
