Does these services are monitored using nagios?
siriideepak
Post by siriideepak »
Hi Guys,
Please update that these services are monitored using nagios
ESX Datastore usage
Cluster status
Snapshot sizes
HA Agents
Check CPU,
Memory,
Network,
VM Status on a VMWare ESX virtual server, via SNMP.
MRTG querying,
Listing VMs/interfaces
NetApps Caches Buffer Cache, FlashCache and FlexCache
Hardware Broken disks, temperature, cooling-devices, power-supplies, nvram
Management High-level overview for decsion-makers
Network Stats per interface (ifnet), Bytes and packets read and sent, errors per second, multicasts, collissions
Performance Operations per second (HTTP, CIFS,, transfer-rate (network, disks, utilization in % (processor, disk), performance per volume (latency, ops)
Snap Available snap-size, lag-time and transfer-errors from SnapMirrors and SnapVaults, utilization of the snap-reserve
Storage Available space for aggregates and volumes, quotas
Status Global System-Status, cluster-status, status (online/offline) of the iSCSI-adapters, RAID-status of aggregates and volumes
WebSite Connectivity
SQL Connections
Resource Utilisation
UCS-Blade
Fabrics Connector
LUN
Exchange Queue
MPLS Links Connectivity between SAJGAS, UGTC, Egypt, Kurdistan, Saudia
IPSEC connectivity
Backup Status
Duration
Retries
Monitoring AreasTask Nagios.doc
Services to be monitored in nagios
(29 KiB) Downloaded 263 times
mguthrie
Re: Does these services are monitored using nagios?
Post by mguthrie »
Nagios can monitor just about anything as long as there's a plugin to do it. Some plugins take more legwork to get set up than others. There's a huge list of community-developed plugins at exchange.nagios.org.
Here's the Core manual for the detailed how-to's.
http://nagios.sourceforge.net/docs/nagi ... n/toc.html
