I have done a fresh install of Nagios Network Analyzer. Everything seemed to install correctly when I went to the URL for Network Analyzer, it asked me to make the nagiosadmin and password. I did so and when I try to log in I got an error that it was unable to find 'type' column in the nagiosna_users table. When looking in the nagiosna.sql that was extracted from the nagiosna-latest.tar.gz it did not have anything on creating the columns of type, auth_server_id, and auth_server_data. To test I added those columns in the table, and then when I try and add a user I get
A Database Error Occurred
Error Number: 1146
Table 'nagiosna.nagiosna_auth_servers' doesn't exist
SELECT * FROM (`nagiosna_auth_servers`)
Filename: /var/www/html/nagiosna/application/controllers/admin.php
Line Number: 130
Anyone else have issues like this?
[Solved] - Missing Fields and Tables from Fresh Install
npolovenko
- Support Tech
Re: Missing Fields and Tables from Fresh Install
Hello, @cmlytle. Is this a clean install on a clean server? No other software was installed on this server before? And no leftover databases left from previous installs? Also, what is the operating system?
Hello npolovenko,
After posting this, I was able to work with a Nagios technician on a call and get it resolved.
It turned out there was some things stuff left over from a non-successful install. After we re-installed the mariadb/mysql and recreated the database and imported the sql and did a full install it resolved the issues.
This happened on a fresh OS install of RHEL 7.5.
To note if you get it installed and when you try and remove the a source and you get a dialog to remove and you ok and then a blank dialog this is most likely the sudoers files for the nna ID is not correctly implemented.
Thank you at Nagios for the quick response and the help.
npolovenko
- Support Tech
Re: [Solved] - Missing Fields and Tables from Fresh Install
@cmlytle, Glad we were able to help you and thanks for the follow-up. I will be closing this thread as resolved.
