Is there a way to access Nagios Fusion dashboard pop outs without authentication for a wall display?
Dashboard pop outs without authentication
npolovenko
- Support Tech
Re: Dashboard pop outs without authentication
Hello, @aeckland1. As of right now, Fusion does not support bypassing the authentication or using a backend ticket.
You could increase the session.gc_maxlifetime value to 31536000 in the php.ini file and Fusion will not exit out of the session. That way a dashboard can stay on the screen for a year.
This would work once the screen has authenticated but need a way for the screen to authenticate with out user interaction. Is this possible?
Hi Nagios Support I was able to achieve an auto login so you can disregard my last post. Also thanks for the guidance on setting the timeout.
Thanks August
Thanks August
npolovenko
- Support Tech
@aeckland1, Yeah, I was about to suggest the AutoLogin. Glad you figured it out.
I will be closing this thread as resolved.
