Any way to provide TOP processes utilizing RAM in peaks
dlukinski
Post by dlukinski »
Hello XI Support
Is there a way (was it ever built for anyone) to list the TOP processes utilizing RAM when the WARN/CRIT thresholds are reached?
So that we could connect the Overutilization to what is causing it?
Thank you
Re: Any way to provide TOP processes utilizing RAM in peaks
Would this plugin be what you are looking for?
https://exchange.nagios.org/directory/P ... rs/details
Or this one?
https://exchange.nagios.org/directory/P ... es/details
We would have to get more details on the remote OS you are monitoring and which Agent is installed on them.
dlukinski
Post by dlukinski »
[quote="tgriep"]Would this plugin be what you are looking for?
Or this one?
Hi
I tried using Linux ones, troubles with both and it looks like only CPU might be fixable in the end.
Memory does not work: have you tested one yourself?
Thank you
I found this powershell script that says it will check the current CPU load (percentage and queue) and physical memory utilization on a windows host and alert based on your arguments. If alerting, it will tell you what process is using the most resources and give you the PID so you can kill it with psexec if the host is inaccessible via traditional methods.
You would use it in conjunction with the NSClient++ agent.
https://exchange.nagios.org/directory/P ... 29/details
