How many items can be added into the actions component. I can only add 5 items via the edit actions option .
I would like to add many more, that would only appear depending on certain criteria.
Is this possible?
Nagios actions
Re: Nagios actions
What is the version of Nagios XI that you are currently using?
When you enable all of the actions under the "Actions" page, and click on Apply Settings", a new empty "template" should show up on the bottom of the page, that you can edit, and enable.
Can you give it a try and let us know if it works for you?
sanjayhiranisq
Re: Nagios actions
Yes this works great
thank you
thank you
Re: Nagios actions
I am glad I could help!
