Hello, I'm running v5.5.3 64-bit VM CentOS7.
I'm trying to pass along the first critical alert to an application, but not any subsequent alerts, while other alerts got to support staff as usual.
This turns out to be much harder than I expected.
I have seen first critical alerts where the $SERVICENOTIFICATIONNUMBER$ is 1 or 2.
I have seen first critical alerts where the $LASTSERVICESTATE$ is critical, possibly due to retesting the probe twice before a hard critical is declared.
There may be the same problem with $HOSTNOTIFICATIONNUMBER$ and $LASTHOSTSTATE$.
Earl
Notification number and last state macros
Bitflogger
Bitflogger
Re: Notification number and last state macros
I should add, that the alerts go through a program.
The program tries to determine from the notification number and last state if it should pass the alert along.
npolovenko
- Support Tech
Hello, @Bitflogger. I'd probably try to use a custom event handler that only sends a notification to the ticketing system on a first state change and doesn't do anything on all subsequent changes. We don't have that script so you'd need to write your own. But you can find examples of the event handler script syntax in this tutorial.
Bitflogger
I have the alerts going to a
Bitflogger
I want to send alerts more than once to support staff, using the standard notification interval.
I have what I need, conceptually, to filter out the first alert.
Operationally, I need the $SERVICENOTIFICATIONNUMBER$ and/or $LASTSERVICESTATE$ to work correctly.
Earl
Earl
Bitflogger
Not a big deal, I can work around it.
Please consider checking this for a future release.
Earl
Earl
npolovenko
- Support Tech
@Bitflogger, We had a few bug fixes in the recent releases of XI, including the one related to performance counters issues. Please go ahead and upgrade to XI 5.5.6 and let me know if you're still experiencing the issue.
https://assets.nagios.com/downloads/nag ... ctions.pdf
