Differing results from same probe using NRPE
Bitflogger
Post by Bitflogger »
Hello, I'm running v5.5.5, 64-bit, VM, CentOS 7
We have a command that is run on over 100 servers, and it works fine on all but two servers.
The same command run on the command line, from the XI server, to the problem servers works fine.
[ead@winston nagios-extra]$ date
Thu Nov 1 11:04:33 CDT 2018
[ead@winston nagios-extra]$ ./check_nrpe_2.15 -H ldap15.doit.wisc.edu -u -t 30 -c disk_ldap15.doit.wisc.edu
DISK OK| /=3118MB;8561;8745;0;9206 /boot=183MB;467;477;0;503 /tmp=39MB;943;964;0;1015 /var=967MB;4752;4854;0;5110 /home=45MB;1893;1934;0;2036 /var/tmp=39MB;943;964;0;1015 /usr/local/mst=446MB;4750;4852;0;5108 /var/lib/docker=86MB;9510;9714;0;10226 /var/lib/mst=75383MB;114250;116707;0;122850 /var/log=162MB;943;964;0;1015 /var/log/audit=56MB;943;964;0;1015 /var/log/mst=32MB;9510;9714;0;10226 /var/lib/docker/containers=86MB;9510;9714;0;10226 /var/lib/docker/devicemapper=86MB;9510;9714;0;10226 /var/lib/rancher/volumes=967MB;4752;4854;0;5110 /var/lib/kubelet=967MB;4752;4854;0;5110
The XI service returns: NRPE: Command 'disk_ldap15.doit.wisc.edu' not defined
The XI command is:
service_description l_disk
use generic-linux-service-disk
hostgroup_name _linux
check_command check_nrpe!disk_$HOSTNAME$!!!!!!!
is_volatile 0
process_perf_data 1
notification_interval 240
first_notification_delay 10
register 1
command_name check_nrpe
command_line $USER5$/check_nrpe_2.15 -H $HOSTADDRESS$ -u -t 30 -c $ARG1$
Earl
Bitflogger
Re: Differing results from same probe using NRPE
Please hold, we have identified a IP problem.
Bitflogger
Please close, host name did match address.
Earl
benjaminsmith
Post by benjaminsmith »
Hi Earl,
Glad to hear you found the problem. I'll close the case.
Thank you for using the Nagios Support Forums.
