nagios plugins to check service httpd status
kaushalshriyan
Post by kaushalshriyan »
I have checked on https://exchange.nagios.org regarding monitoring of /etc/init.d/httpd status and could not find any specific plugin to monitor it. For example if status returns failed or not ok nagios should trigger alert.
Redirecting to /bin/systemctl status httpd.service
● httpd.service - The Apache HTTP Server
   Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; vendor preset: disabled)
   Active: active (running) since Sun 2018-10-21 02:32:54 UTC; 1 weeks 4 days ago
     Docs: man:httpd(8)
           man:apachectl(8)
  Process: 17453 ExecStop=/bin/kill -WINCH ${MAINPID} (code=exited, status=0/SUCCESS)
  Process: 2831 ExecReload=/usr/sbin/httpd $OPTIONS -k graceful (code=exited, status=0/SUCCESS)
 Main PID: 17462 (httpd)
   Status: "Total requests: 0; Current requests/sec: 0; Current traffic:   0 B/sec"
   CGroup: /system.slice/httpd.service
           ├─ 2873 perl -x /usr/share/thruk/thruk_auth
           ├─ 2874 /usr/sbin/httpd -DFOREGROUND
           ├─ 2876 /usr/sbin/httpd -DFOREGROUND
           ├─ 2878 /usr/sbin/httpd -DFOREGROUND
           ├─12029 /usr/bin/perl /usr/share/thruk/script/thruk_fastcgi.pl
           ├─12042 /usr/sbin/httpd -DFOREGROUND
           ├─12047 /usr/sbin/httpd -DFOREGROUND
           ├─12069 /usr/sbin/httpd -DFOREGROUND
           ├─12079 /usr/sbin/httpd -DFOREGROUND
           ├─12082 /usr/bin/perl /usr/share/thruk/script/thruk_fastcgi.pl
           ├─15833 /usr/sbin/httpd -DFOREGROUND
           ├─16350 /usr/sbin/httpd -DFOREGROUND
           ├─16367 /usr/sbin/httpd -DFOREGROUND
           ├─16398 /usr/sbin/httpd -DFOREGROUND
           └─17462 /usr/sbin/httpd -DFOREGROUND
Any help will be highly appreciable.
Best Regards,
Kaushal
benjaminsmith
Re: nagios plugins to check service httpd status
Post by benjaminsmith »
Hi @Kaushal
You can use NRPE to monitor services and processes like httpd. Follow the instructions below for installing NRPE on your sever.
https://assets.nagios.com/downloads/nag ... _Agent.pdf and use check_init_service to determine if httpd is running or not.
Service Checks in Nagios
https://support.nagios.com/kb/article/s ... s-775.html
Please let me know if you are able to get it setup.
kaushalshriyan
Hi Benjamin Smith,
Thanks for your email and appreciate your help. I am running Nagios Core 4.3.4 in my environment and i have already setup nrpe agent on all the client nodes. Is there a way to install check_init_service in /usr/lib/nagios/plugins/ as Nagios plugin?
# cat /etc/redhat-release
CentOS Linux release 7.5.1804 (Core)
# rpm -qa | grep nrpe
nrpe-plugin-3.2.1-1.x86_64
nrpe-3.2.1-1.x86_64
# ls /usr/lib/nagios/plugins/ -l
total 2528
-rwxr-xr-x. 1 nagios nagios  54712 Apr 13  2018 check_apt
-rwxr-xr-x. 1 nagios nagios   2340 Apr 13  2018 check_breeze
-rwxr-xr-x. 1 nagios nagios  59320 Apr 13  2018 check_by_ssh
lrwxrwxrwx. 1 nagios nagios      9 Apr 13  2018 check_clamd -> check_tcp
-rwxr-xr-x. 1 nagios nagios  46136 Apr 13  2018 check_cluster
-rwxr-xr-x. 1 nagios nagios   6532 Apr 13  2018 check_cpu_perf.sh
-rwxr-xr-x. 1 nagios nagios  58944 Apr 13  2018 check_dhcp
-rwxr-xr-x. 1 nagios nagios  59096 Apr 13  2018 check_dig
-rwxr-xr-x. 1 nagios nagios  63800 Apr 13  2018 check_disk
-rwxr-xr-x. 1 nagios nagios   9463 Apr 13  2018 check_disk_smb
-rwxr-xr-x. 1 nagios nagios  63088 Apr 13  2018 check_dns
-rwxr-xr-x. 1 nagios nagios  37216 Apr 13  2018 check_dummy
-rwxr-xr-x. 1 nagios nagios   3854 Apr 13  2018 check_file_age
-rwxr-xr-x. 1 nagios nagios   6498 Apr 13  2018 check_flexlm
lrwxrwxrwx. 1 nagios nagios      9 Apr 13  2018 check_ftp -> check_tcp
-rwxr-xr-x. 1 nagios nagios  54648 Apr 13  2018 check_hpjd
-rwxr-xr-x. 1 nagios nagios 105576 Apr 13  2018 check_http
-rwxr-xr-x. 1 nagios nagios  62624 Apr 13  2018 check_icmp
-rwxr-xr-x. 1 nagios nagios  46336 Apr 13  2018 check_ide_smart
-rwxr-xr-x. 1 nagios nagios  15269 Apr 13  2018 check_ifoperstatus
-rwxr-xr-x. 1 nagios nagios  13417 Apr 13  2018 check_ifstatus
lrwxrwxrwx. 1 nagios nagios      9 Apr 13  2018 check_imap -> check_tcp
-rwxr-xr-x. 1 nagios nagios   6978 Apr 13  2018 check_ircd
lrwxrwxrwx. 1 nagios nagios      9 Apr 13  2018 check_jabber -> check_tcp
-rwxr-xr-x. 1 nagios nagios  55040 Apr 13  2018 check_ldap
lrwxrwxrwx. 1 nagios nagios     10 Apr 13  2018 check_ldaps -> check_ldap
-rwxr-xr-x. 1 nagios nagios  50280 Apr 13  2018 check_load
-rwxr-xr-x. 1 nagios nagios   6669 Apr 13  2018 check_log
-rwxr-xr-x. 1 nagios nagios  22727 Apr 13  2018 check_mailq
-rwxr-xr-x. 1 nagios nagios  13159 Apr 13  2018 check_mem.pl
-rwxr-xr-x. 1 nagios nagios  50296 Apr 13  2018 check_mrtg
-rwxr-xr-x. 1 nagios nagios  46120 Apr 13  2018 check_mrtgtraf
-rwxr-xr-x. 1 nagios nagios  59160 Apr 13  2018 check_mysql
-rwxr-xr-x. 1 nagios nagios  54768 Apr 13  2018 check_mysql_query
-rwxr-xr-x. 1 nagios nagios  50320 Apr 13  2018 check_nagios
lrwxrwxrwx. 1 nagios nagios      9 Apr 13  2018 check_nntp -> check_tcp
lrwxrwxrwx. 1 nagios nagios      9 Apr 13  2018 check_nntps -> check_tcp
-rwxr-xr-x. 1 nagios nagios  50696 Apr 13  2018 check_nrpe
-rwxr-xr-x. 1 nagios nagios  62840 Apr 13  2018 check_nt
-rwxr-xr-x. 1 nagios nagios  58888 Apr 13  2018 check_ntp
-rwxr-xr-x. 1 nagios nagios  59072 Apr 13  2018 check_ntp_peer
-rwxr-xr-x. 1 nagios nagios  54712 Apr 13  2018 check_ntp_time
-rwxr-xr-x. 1 nagios nagios  70920 Apr 13  2018 check_nwstat
-rwxr-xr-x. 1 nagios nagios   9457 Apr 13  2018 check_oracle
-rwxr-xr-x. 1 nagios nagios  54536 Apr 13  2018 check_overcr
-rwxr-xr-x. 1 nagios nagios  59120 Apr 13  2018 check_pgsql
-rwxr-xr-x. 1 nagios nagios  63104 Apr 13  2018 check_ping
lrwxrwxrwx. 1 nagios nagios      9 Apr 13  2018 check_pop -> check_tcp
-rwxr-xr-x. 1 nagios nagios  63296 Apr 13  2018 check_procs
-rwxr-xr-x. 1 nagios nagios  50512 Apr 13  2018 check_real
-rwxr-xr-x. 1 nagios nagios   9673 Apr 13  2018 check_rpc
-rwxr-xr-x. 1 nagios nagios   1533 Apr 13  2018 check_sensors
lrwxrwxrwx. 1 nagios nagios      9 Apr 13  2018 check_simap -> check_tcp
-rwxr-xr-x. 1 nagios nagios  67816 Apr 13  2018 check_smtp
-rwxr-xr-x. 1 nagios nagios  80248 Apr 13  2018 check_snmp
lrwxrwxrwx. 1 nagios nagios      9 Apr 13  2018 check_spop -> check_tcp
-rwxr-xr-x. 1 nagios nagios  50520 Apr 13  2018 check_ssh
lrwxrwxrwx. 1 nagios nagios      9 Apr 13  2018 check_ssmtp -> check_tcp
-rwxr-xr-x. 1 nagios nagios  46056 Apr 13  2018 check_swap
-rwxr-xr-x. 1 nagios nagios  63616 Apr 13  2018 check_tcp
-rwxr-xr-x. 1 nagios nagios  50464 Apr 13  2018 check_time
lrwxrwxrwx. 1 nagios nagios      9 Apr 13  2018 check_udp -> check_tcp
-rwxr-xr-x. 1 nagios nagios  54600 Apr 13  2018 check_ups
-rwxr-xr-x. 1 nagios nagios  46096 Apr 13  2018 check_uptime
-rwxr-xr-x. 1 nagios nagios  41880 Apr 13  2018 check_users
-rwxr-xr-x. 1 nagios nagios   3026 Apr 13  2018 check_wave
-rwxr-xr-x. 1 nagios nagios  46000 Apr 13  2018 negate
-rwxr-xr-x. 1 nagios nagios  41680 Apr 13  2018 urlize
-rwxr-xr-x. 1 nagios nagios   1933 Apr 13  2018 utils.pm
-rwxr-xr-x. 1 nagios nagios   2791 Apr 13  2018 utils.sh
I look forward to hearing from you.
Best Regards,
Kaushal
attached is the script
You would need to add something like the following to nrpe.cfg
sudo /usr/lib/nagios/plugins/check_init_service $ARG1$
Also, this plugin required a sudoers entry like the following
nagios ALL=NOPASSWD: /usr/local/nagios/libexec/check_init_service
check_init_service.zip
(542 Bytes) Downloaded 372 times
