Hi Guys,
I'm running 20,000+ checks on a Nagios instance. I'm trying to return the Services object(s) through the API. Subsequently Nagios is returning a 500 error. What's the Max number of JSON objects I can return via the API? Note: Filtering via say "host_name" works.
Maxwell Ramirez
API Return Limit
Re: API Return Limit
There isn't a maximum, however you are likely hitting a php memory_limit
edit /etc/php.ini and increase the memory_limit
restart httpd
memory_limit = 256MCode: Select all
service httpd restart-
Maxwellb99
haha, yeah I trust you. It works for me on python so I figured it was some config holding me back. I threw 2G of mem at it, but I think I'm going to have to split it up. Well it was fun while it lasted. Still getting a 500 error, but we're ok. Please close this thread. Thanks.
closingMaxwellb99 wrote:haha, yeah I trust you. It works for me on python so I figured it was some config holding me back. I threw 2G of mem at it, but I think I'm going to have to split it up. Well it was fun while it lasted. Still getting a 500 error, but we're ok. Please close this thread. Thanks.
