Hello Nagios Support
How to dashboard group of services as a single tile?
Say we have a group of service checks, representing SLA of an Application (many groups for different applications)
Now, we would want to have these multiple groups in a single dashboard?
- How could we do that?
I see one option if we were to BPI such groups and present them via Fusion (we do have Fusion). Would this work?
https://assets.nagios.com/downloads/nag ... 1498579208
npolovenko
- Support Tech
Re: How to dashboard group of services as a single tile?
@dlukinski , You could add servicegroup status summary dashlets to a single dashboard by clicking on the blue icon in the left corner.
Did I get your question? Or do you specifically want to add service checks/service group status dashlets to a dashboard in Fusion?
we need only specific Groups, not all of them. Say there are 10-20 Applications, all having the certain number of checks listed.npolovenko wrote:@dlukinski , You could add servicegroup status summary dashlets to a single dashboard by clicking on the blue icon in the left corner. Did I get your question? Or do you specifically want to add service checks/service group status dashlets to a dashboard in Fusion?
We are trying to represent these a 1 tile per application (different color if OK/CRIT/WARN) and wonder what could be done about it?
npolovenko
- Support Tech
@dlukinski, You could put your application with its services in a service group, and then add individual service group dashlets to your dashboard.
Would that work?
No it would not, application SLA checks could easily count a 100 with overall checks being in many hundredsnpolovenko wrote:@dlukinski, You could put your application with its services in a service group, and then add individual service group dashlets to your dashboard. Would that work?
npolovenko
- Support Tech
@dlukinski, What about the Service Group Status dashlets? They do not list each service, just give you the numbers of OK/Critical services in a service group.
