Ping check issue
kwhogster
Ping check issue
Post by kwhogster »
Nagios Core 4.3.4
Having a minor issue with PING check on one host The Host is my vCenter appliance
        use                             local-service
        host_name                       hostname
        service_description             PING
        check_command                   check_ping!100.0,20%!500.0,60%
[code]
PING     WARNING 11-02-2018 21:39:08 0d 0h 16m 45s 4/4 PING WARNING - Packet loss = 0%, RTA = 118.81 ms
From My desktop
[codePinging host-vc[10.2.8.11] with 32 bytes of data:
Reply from 10.2.8.11: bytes=32 time=92ms TTL=64
Reply from 10.2.8.11: bytes=32 time=121ms TTL=64
Reply from 10.2.8.11: bytes=32 time=57ms TTL=64
Reply from 10.2.8.11: bytes=32 time=105ms TTL=64
Ping statistics for 10.2.8.11:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 57ms, Maximum = 121ms, Average = 93ms]
Any ideas?
Re: Ping check issue
From your nagios server it is seeing slightly higher RTA at 118.81 ms
If this is normal you may want to increase the warning time to 200 as an example
check_command                   check_ping!200.0,20%!500.0,60%
kwhogster
Post by kwhogster »
still having the issue
PING WARNING 11-13-2018 13:18:02 0d 1h 22m 9s 4/4 PING WARNING - Packet loss = 0%, RTA = 132.10 ms
kwhogster wrote:still having the issue
what is your current check_command definition?
kwhogster
Post by kwhogster »
OOPS
I forgot to change it.
As I stated before
scottwilkerson wrote: If this is normal you may want to increase the warning time to 200 as an example
kwhogster
Post by kwhogster »
Scott
I made the correction.
Then I went on to my vCenter and found all my nics reverted back to 100 MBs they were at 1000 MBs
My Cisco switch set all the ports to 100 MBs they all were 1000 before then when we looked at the config it only supports 10/100 do not know how everything was 1 GBs and now only 100
waiting on a replacement switch
Will post after that change is made.
kwhogster wrote:Scott
Thanks for the update!
