How to monitor network equipment using SNMP and factory MIB's
Hello! I am running Nagios XI in a VM environment for evaluation purposes. We plan to purchase either Nagios XI or Microsoft SCOM.
I am attempting to monitor our Cisco ASA 5520’s and F5 LTM 1600 link controllers. I have downloaded and imported the MIB files to Nagios and also confirm that they are available via the interface.
Basically, I am looking for a method to monitor uptime, response time (yes, I am using check_ping already), network port utilization and status (i.e. up or down), temperature sensors, fans, etc. Basically, I want to monitor every aspect of these devices.
I have performed an SNMP walk using the XI GUI but, it doesn’t appear to be referencing the items in the F5-BIGIP-SYSTEM-MIB file (or any others). It does reference IF-MIB and various other default MIBs.
I have searched the administrator guide and what I am looking for is a form of documentation with setting up configuring monitors for network devices using advanced features by utilizing the factory MIB’s via SNMP.
Any help would be appreciated.
Bryce
how to monitor network equipment using MIB's
brycejohnson
Re: how to monitor network equipment using MIB's
I am having similiar issues with Sonciwall NSA 2400 firewalls. The mibs exist but the snmp walk wizard appears to only list a limited number of Objects.
I have increased the load time and the number to display and also forced a rescan but only see the defaults.
Did you ever get an answer?
If you do walk from the cli, are any of the Cisco MIBS listed?
snmpwalk -c <community> -v 1 <ip of cisco device>Former Nagios employee
