percentage on the performance graph?!
is there possible to display percentage on the performance graph?!
npolovenko
- Support Tech
Re: percentage on the performance graph?!
Hello, @xpertech. That depends on the individual plugin. It needs to return the perfdata output with % sign.
'label'=value%;[warn];[crit];[min];[max]
Sometimes, plugins return perdata output in MB or other units and that can't be changed without modifying the source code.
https://nagios-plugins.org/doc/guidelin ... 015#AEN200
