Bulk Clone Wizard Failing to Clone Properly
mkeey
Post by mkeey »
Using the Bulk Clone Wizard I'm getting the following error...
Was working but recently upgraded to v5.5.5.
Last edited by benjaminsmith on Tue Feb 19, 2019 12:08 pm, edited 1 time in total.
Reason: output removed at request
Re: Bulk Clone Wizard Failing to Clone Properly
After consulting with the developers about the cause of this, we did come up with a cause and that is the file format changes slightly in the newer versions and need to be re-written to be parsed correctly.
Lets to the following. Remove the erroneous configs for the host/services, in the CCM.
Then
CCM -> Tools -> Config File Management
Delete Files
Write Configs
Verify Files
Restart Nagios Core
This will reset the configs
Now, the Bulk Host Import Wizard should work correctly.
mkeey
Post by mkeey »
I will give that a go this morning - MKeey
mkeey
Post by mkeey »
Attempted what you had requested. See attached PDF for screen prints of failed results. Please advise - MKeey
Go to CCM -> hosts
delete ***host
the proceed again
Sorry I wasn't clear, that's what I meant by
scottwilkerson wrote:Remove the erroneous configs for the host/services, in the CCM.
mkeey
Post by mkeey »
Hello Scott - I appreciate that I can delete the bad services/hosts via the CCM. Did that yesterday and then the Apply Config works just fine. However, I still have to add these new hosts & services. If I run the Bulk Clone Wizard again, I'll just be right back where I started from.
I will delete the bad CFG files, but how do we fix the problem of the Wizard generating corrupt/incompatible CFG files?
Actually when you ran this it would have fixed the issue
Delete Files
Write Configs
there was a bug that required all the configs to be re-written for the Bulk Host cloning issue to be resolved.
Now if you re-run the wizard it should create the hosts correctly.
mkeey
Post by mkeey »
This makes sense now. Should have cleaned up the old versions CFG files before we ran the Wizard. May want to update the upgrade program to include a delete of the CFG files so other customers don't run into this issue.
mkeey wrote:This makes sense now. Should have cleaned up the old versions CFG files before we ran the Wizard. May want to update the upgrade program to include a delete of the CFG files so other customers don't run into this issue.
Agreed.
Were you able to run the Bulk Host Cloning Wizard successfully?
mkeey
Post by mkeey »
Affirmative, the Bulk Clone Wizard worked as it always has. Please consider this post resolved. Thanks for the help!
