Nagios GUI defaulted back to older version.
vy3734
Post by vy3734 »
My Nagios web interface defaulted back to older version automatically. How can i upgrade it back to the new version without having to re-install the Nagisoxi. Please help!
Thanks!
cdienger
Re: Nagios GUI defaulted back to older version.
Post by cdienger »
The XI interface can be reached by going to http(s)://nagios_ip/nagiosxi but the old interface is still reachable at http(s)://nagios_ip/nagios. Make sure you're browser is pointing to the correct location.
vy3734
Post by vy3734 »
I am using the nagiosxi URL http://NagiosServer/nagiosxi/index.php?
cdienger
Post by cdienger »
Is the URL in the address bar getting redirected? Are you hitting a XI login page at all?
Check /etc/httpd/conf.d/nagiosxi.conf which should contain:
<Directory "/usr/local/nagiosxi/html">
#  SSLRequireSSL
   Options None
   AllowOverride None
   Order allow,deny
   Allow from all
#  Order deny,allow
#  Deny from all
#  Allow from 127.0.0.1
   AuthName "Nagios XI"
   AuthType Basic
   AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
   Require valid-user
   Require all granted
</Directory>
Alias /nagiosxi "/usr/local/nagiosxi/html"
# Special configuration to allow .htaccess in custom includes
<Directory "/usr/local/nagiosxi/html/includes/components/custom-includes">
    AllowOverride All
    Options None
   Require all granted
</Directory>
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule nagiosxi/api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request=$1 [QSA,NC,L]
</IfModule>
vy3734
Post by vy3734 »
nagiosxi.conf file has similar settings as specified in the example above.
I tried hitting both the URLs
http://NagiosServer/nagios/
you were right about the URL with just nagios pointing to the older version, but in my case nagiosxi is also pointing to the older version.
The only difference i saw in the file you posted above vs what i have on my server is
AuthType Basic
I had the above lines commented in my file.
the Alias line was the same too?
If so, I would recommend you tar up the contents of /etc/httpd/conf.d and send them in for us to have a look at
Upload the files that @scottwilkerson asked for as well as this file from the server.
/etc/httpd/conf/httpd.conf
vy3734
Post by vy3734 »
Attaching the conf.d tar ball and the httpd.conf file as requested.
httpd.conf
conf.d.tar.gz
What version of Nagios XI is installed on the server?
What OS and release is the server running.
Try this, edit the /etc/httpd/conf.d/nagiosxi.conf file and comment out these lines.
   AuthType Basic
   Require valid-user
   Require all granted
   Require all granted
   Require all granted
   Require all granted
   Require all granted
Save the settings and restart Apache by running
service httpd restart
Then try and login to the XI GUI and let us know what happens.
vy3734
Post by vy3734 »
Nagios XI 5.2.3
Red Hat Enterprise Linux Server release 7.5 (Maipo)
Tried commenting the lines mentioned, after the httpd restart i started seeing the following message
Reverted back the changes to access the gui again. Still seeing the same issue.
