NagiosXI 5.5.5 - NRPE Wizard issues...
vishfx
Post by vishfx »
Hi Nagios Team,
I have installed nrpe by following https://assets.nagios.com/downloads/nag ... _Agent.pdf
I have used NRPE Wizard to monitor host.
NREP Wizard apply changes went thorough fine and verification completed.
However after the apply changes, nagios core backend service is not starting up.
nagios core backend service to started after reverting to a older snapshot.
Below are the cmdsys log o/p :
..............................PROCESSING COMMAND ID 996...
PROCESS COMMAND: CMD=17, DATA=
APPLYING NAGIOSCORE CONFIG...
CMDLINE=cd /usr/local/nagiosxi/scripts && ./reconfigure_nagios.sh
No entry for terminal type "unknown";
using dumb terminal settings.
--- reset_config_perms.sh ------------
> Setting CCM script permissions
> Setting script permissions
> Setting special component script permissions
> Setting configuration file/directory permissions
> Setting perfdata directory and RRD permissions
> Setting NOM checkpoint user:group permissions
> + Setting CCM configuration file user:group permissions
> + Setting Recurring Downtime file user:group permissions
> + Setting BPI configuration file user:group permissions
--- ccm_import.php -------------------
> Setting import directory: /usr/local/nagios/etc/import/
> Importing config files into the CCM
  - Importing: /usr/local/nagios/etc/import/PZeNQ5Xv.tmp.cfg .. SUCCESS
  - Importing: /usr/local/nagios/etc/import/cpsnxiwtst01.isus.emc.com.cfg .. SUCCESS
--- ccm_export.php -------------------
> Writing CCM configuration to Nagios files
  Finished writing out configuraton
> Verifying configuration with Nagios Core
> Output:
Nagios Core 4.2.4
Last Modified: 12-07-2016
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
        Checked 2078 services.
        Checked 23 hosts.
        Checked 4 host groups.
        Checked 2 service groups.
        Checked 2 contacts.
        Checked 3 contact groups.
        Checked 132 commands.
        Checked 7 time periods.
        Checked 0 host escalations.
        Checked 23 hosts
        Checked 5680 service dependencies
        Checked 34 host dependencies
        Checked 7 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
> Return Code: 0
PROCESSED 0 COMMANDS
...OUTPUT=--------------------------------------
RETURNCODE=0
PROCESSED 1 COMMANDS
PROCESSING COMMAND ID 997...
PROCESS COMMAND: CMD=1150, DATA=remove
CMDLINE=php /usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php --cmd=syncall
PHP Notice:  Undefined variable: err in /usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php on line 150
CMD: syncall
MSG: Could not get data for objects. NDO or Core may not be running.
OUTPUT=MSG: Could not get data for objects. NDO or Core may not be running.
RETURNCODE=0
Kindly assist.
Regards,
Vish.
npolovenko
Re: NagiosXI 5.5.5 - NRPE Wizard issues...
Post by npolovenko »
Hello, @vishfx. You don't need to install NRPE agent on the XI server because it already comes pre-installed with it.
Are you experiencing any problems at all after you reverted to the past snapshot? Please rerun the NRPE wizard and if you start getting problems send us your system profile.
To send us your system profile. Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and send it in a private message.
After you send a profile please post something in this thread to bring it back up in the support queue.
vishfx
Post by vishfx »
I am not referring to nrpe installed on NagiosXI web node.
In this case its a remote system, where nrpe agent is running.
Have PM the profile.zip.
Regards,
Vish.
npolovenko
@vishfx, I don't see anything outstanding in the profile. Probably because you reverted to a good snapshot and old logs were already rotated. I suggest opening a support ticket with me here: https://support.nagios.com/tickets . That way we can schedule a quick remote session and I'll see how you're adding nrpe hosts and what exactly is breaking. Let me know if you think that would work for you? Otherwise, I will provide you with further text instructions on the forum.
