Metrics Display not showing data from check_nrpe checks
Fred Kroeger
Post by Fred Kroeger »
Hi - Just run up a new XI 5.5.6 server and having problems with displaying metrics.
CPU, Disk & Memory usage work OK for checks by check_nt on Windows servers.
However when I run the equivalent check on those servers using check_nrpe, none of those checks are displayed in the Metrics screen.
What is the format of the check_nrpe commands so that they appear on the Metrics screen?
regards... Fred
ssax
Dreams In Code
Re: Metrics Display not showing data from check_nrpe checks
Post by ssax »
It should be using the check_mem check_nrpe command, those are the only ones that will show up for the memory metrics for check_nrpe. Is that what they are using?
Fred Kroeger
Yes for the memory checks I am using check_memory.
The check_xi_service_nsclient commands are the default as per the wizard - they display OK in the Metrics page
The check_nrpe commands are what I have created and don't display in the Metrics page. I would prefer to use the check_nrpe commands as it gives me a lot more flexibility in filtering and output display.
check_nrpe
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c check_memory -a "warn=free < 20%" "crit=free < 10%"
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c check_cpu -a "warn=load > 80" "crit=load > 90"
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c check_drivesize -a "warn=free < 20%" "crit=free < 10%" drive=c:
$USER1$/check_nt -H $HOSTADDRESS$ -s "" -p 12489 -v MEMUSE -w 80 -c 90
$USER1$/check_nt -H $HOSTADDRESS$ -s "" -p 12489 -v CPULOAD -l 5,80,90
$USER1$/check_nt -H $HOSTADDRESS$ -s "" -p 12489 -v USEDDISKSPACE -l C -w 80 -c 95
As an example this the Service status for Memory checks (Memory Usage = check_nrpe & Memory Utilsation = check_nt)
	   Memory Usage	Ok	1d 0h 56m 44s	1/4	09/11/2018 12:23:15	Memory Usage: OK
 Memory Utilisation	Ok	1d 0h 25m 24s	1/5	09/11/2018 12:21:39	Memory usage: total:2569.01 MB - used: 1583.39 MB (62%) - free: 985.62 MB (38%)
I did swap around the Service names in case the Metrics Page was using the name as a filter but that made no difference.
ssax
Dreams In Code
Post by ssax »
So your check_memory command only outputs Memory Usage: OK?
What is the full output of this command and I'll see if we can get it working for you:
- Change X.X.X.X to one of your windows servers
/usr/local/nagios/libexec/check_nrpe -H X.X.X.X -t 30 -c check_memory -a "warn=free < 20%" "crit=free < 10%"
Fred Kroeger
Thanks command & ouput listed below
# /usr/local/nagios/libexec/check_nrpe -H X.X.X.X -t 30 -c check_memory -a "warn=free < 20%" "crit=free < 10%"
OK: committed = 1.571GB, physical = 1.276GB|'committed'=960.42187MB;513.79765;256.89882;0;2568.98828 'committed %'=37%;20;10;0;100 'physical'=738.4375MB;409.00546;204.50273;0;2045.02734 'physical %'=36%;20;10;0;100
Snip from Service Status screen : Memory Usage is the check_nrpe service & Memory Utilisation is the check_nt service
	  Memory Usage	Ok	2d 9h 42m 26s	1/4	10/11/2018 21:08:35	OK: committed = 1.571GB, physical = 1.275GB
Memory Utilisation	Ok	2d 9h 11m 36s	1/5	10/11/2018 21:08:13	Memory usage: total:2569.01 MB - used: 1608.19 MB (63%) - free: 960.82 MB (37%)
ssax
Dreams In Code
Post by ssax »
I'm labbing this up and trying to get you a solution, I'll let you know the results by the end of the day.
ssax
Dreams In Code
Post by ssax »
Please include sample outputs of the other ones as well:
Fred Kroeger
NRPE commands
./check_nrpe -H X.X.X.X -t 30 -c check_cpu -a "warn=load > 80" "crit=load > 90"
OK: CPU load is ok.|'total 5m'=0%;80;90 'total 1m'=0%;80;90 'total 5s'=0%;80;90
./check_nrpe -H X.X.X.X -t 30 -c check_drivesize -a "warn=free < 20%" "crit=free < 10%" drive=c:
OK All 1 drive(s) are ok|'c: free'=110.18499GB;25.28925;12.64462;0;126.44628 'c: free %'=87%;20;10;0;100
Corresponding CHECK_NT commands which do display OK in Metrics page
 ./check_nt -H X.X.X.X -p 12489 -v CPULOAD -l 5,80,90
CPU Load 0% (5 min average) |   '5 min avg Load'=0%;80;90;0;100
./check_nt -H X.X.X.X -p 12489 -v USEDDISKSPACE -l C -w 80 -c 95
C:\ - total: 126.45 Gb - used: 16.26 Gb (13%) - free 110.18 Gb (87%) | 'C:\ Used Space'=16.26Gb;101.16;120.12;0.00;126.45
ssax
Dreams In Code
Post by ssax »
Thank you for the output, I will update you later today.
ssax
Dreams In Code
Post by ssax »
Please unzip the attached file and replace this file on your XI server and see if the Memory ones for check_memory show now:
/usr/local/nagiosxi/html/includes/utils-metrics.inc.php
utils-metrics.zip
Let us know the results.
