Hosts still showing up after "restore_defaults.sh"
MattXI
Post by MattXI »
Nagios XI manually installed on RedHat 7
I am trying to clean up a Nagios XI server from all its hosts so I can reconfigure from ground up.
I ran /usr/local/nagiosxi/scripts/restore_defaults.sh and it went okay. Now the CCM only shows "localhost" which is what I want.
Problem is that I still have all my 500+ hosts showing up in Nagios XI dashboard.
If I try to delete a host, I get the following error :
Could not find a unique id for this host
Host cannot be deleted using this method
I have no idea of what's going on here, did I miss something or is my Nagios broken ?
Could you please help me removing all these hosts ?
Regards.
Re: Hosts still showing up after "restore_defaults.sh"
This should remove all the old configs
CCM -> Tools -> Config File Management
Delete Files
Write Configs
Verify Files
Restart Nagios Core
MattXI
Post by MattXI »
Thanks for the answer. I did just that and it went fine but my 500+ hosts are still there.
Note that I went to "system status" and the line "Monitoring Engine" has red status : no lock file found in /usr/local/nagios/var/nagios.lock
This file exists on the server and inside there's nagios PID (the process is up and running)
Action -> start on this service says that my request did not process in a timely manner.
I rebooted the server but everything stays the same. Something is wrong but I don't know what it is.
Here's an extract from nagios.log :
[1541685393] Nagios 4.2.4 starting... (PID=1775)
[1541685393] Local time is Thu Nov 08 14:56:33 CET 2018
[1541685393] LOG VERSION: 2.0
[1541685393] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1541685393] qh: core query handler registered
[1541685393] nerd: Channel hostchecks registered successfully
[1541685393] nerd: Channel servicechecks registered successfully
[1541685393] nerd: Channel opathchecks registered successfully
[1541685393] nerd: Fully initialized and ready to rock!
[1541685393] wproc: Successfully registered manager as @wproc with query handler
[1541685393] wproc: Registry request: name=Core Worker 1780;pid=1780
[1541685393] wproc: Registry request: name=Core Worker 1783;pid=1783
[1541685393] wproc: Registry request: name=Core Worker 1782;pid=1782
[1541685393] wproc: Registry request: name=Core Worker 1781;pid=1781
[1541685393] ndomod: NDOMOD 2.1.2 (11-14-2016) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
[1541685393] ndomod: Could not open data sink!  I'll keep trying, but some output may get lost...
[1541685393] ndomod registered for process data
[1541685393] ndomod registered for log data'
[1541685393] ndomod registered for system command data'
[1541685393] ndomod registered for event handler data'
[1541685393] ndomod registered for notification data'
[1541685393] ndomod registered for comment data'
[1541685393] ndomod registered for downtime data'
[1541685393] ndomod registered for flapping data'
[1541685393] ndomod registered for program status data'
[1541685393] ndomod registered for host status data'
[1541685393] ndomod registered for service status data'
[1541685393] ndomod registered for adaptive program data'
[1541685393] ndomod registered for adaptive host data'
[1541685393] ndomod registered for adaptive service data'
[1541685393] ndomod registered for external command data'
[1541685393] ndomod registered for aggregated status data'
[1541685393] ndomod registered for retention data'
[1541685393] ndomod registered for contact data'
[1541685393] ndomod registered for contact notification data'
[1541685393] ndomod registered for acknowledgement data'
[1541685393] ndomod registered for state change data'
[1541685393] ndomod registered for contact status data'
[1541685393] ndomod registered for adaptive contact data'
[1541685393] Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
[1541685399] Successfully launched command file worker with pid 2061
[1541686294] ndomod: Still unable to connect to data sink.  1032 items lost, 5000 queued items to flush.
Lets run the following
service nagios stop
service ndo2db stop
killall -9 nagios
rm -f /usr/local/nagios/var/ndo* /usr/local/nagios/var/nagios.lock
service ndo2db start
service nagios start
MattXI
Post by MattXI »
The dashboard looks much better indeed ! Only localhost is displayed there.
For some reason the system status still complains about the lockfile and my nagios commands (force check for example) are still not processed.
What is the output of the following commands:
grep nagios.lock /etc/init.d/nagios
grep nagios.lock /usr/local/nagios/etc/nagios.cfg
ls -al /usr/local/nagios/var/rw/
MattXI
Post by MattXI »
Sorry I was ooo last Friday. Here's the output :
# grep nagios.lock /etc/init.d/nagios
# pidfile: /usr/local/nagios/var/nagios.lock
NagiosRunFile=${prefix}/var/nagios.lock
# grep nagios.lock /usr/local/nagios/etc/nagios.cfg
lock_file=/usr/local/nagios/var/nagios.lock
# ls -al /usr/local/nagios/var/rw/
total 8
drwsrwsr-x. 2 nagios nagcmd 4096 Nov  8 15:33 .
drwxrwxr-x. 6 nagios nagios 4096 Nov 12 09:10 ..
prw-rw----  1 nagios nagcmd    0 Nov  8 15:33 nagios.cmd
srw-rw----  1 nagios nagcmd    0 Nov  8 15:33 nagios.qh
# cat /usr/local/nagios/var/nagios.lock
8719
Can you run a Nagios verification command and a process commands and post the output to the ticket?
Run these as root.
ps -ef --cols=300
Also, what version of XI is the server running and can you post the full error message you are receiving?
MattXI
Post by MattXI »
Here's the output :
#     /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.2.4
Last Modified: 12-07-2016
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
        Checked 14 services.
        Checked 1 hosts.
        Checked 1 host groups.
        Checked 0 service groups.
        Checked 2 contacts.
        Checked 2 contact groups.
        Checked 124 commands.
        Checked 8 time periods.
        Checked 0 host escalations.
        Checked 1 hosts
        Checked 0 host dependencies
        Checked 8 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
#     ps -ef --cols=300
UID        PID  PPID  C STIME TTY          TIME CMD
root         1     0  0 Nov08 ?        00:02:04 /usr/lib/systemd/systemd --switched-root --system --deserialize 21
root         2     0  0 Nov08 ?        00:00:00 [kthreadd]
root         3     2  0 Nov08 ?        00:00:00 [ksoftirqd/0]
root         5     2  0 Nov08 ?        00:00:00 [kworker/0:0H]
root         7     2  0 Nov08 ?        00:00:01 [migration/0]
root         8     2  0 Nov08 ?        00:00:00 [rcu_bh]
root         9     2  0 Nov08 ?        00:00:20 [rcu_sched]
root        10     2  0 Nov08 ?        00:00:00 [lru-add-drain]
root        11     2  0 Nov08 ?        00:00:01 [watchdog/0]
root        12     2  0 Nov08 ?        00:00:01 [watchdog/1]
root        13     2  0 Nov08 ?        00:00:01 [migration/1]
root        14     2  0 Nov08 ?        00:00:01 [ksoftirqd/1]
root        16     2  0 Nov08 ?        00:00:00 [kworker/1:0H]
root        18     2  0 Nov08 ?        00:00:00 [kdevtmpfs]
root        19     2  0 Nov08 ?        00:00:00 [netns]
root        20     2  0 Nov08 ?        00:00:00 [khungtaskd]
root        21     2  0 Nov08 ?        00:00:00 [writeback]
root        22     2  0 Nov08 ?        00:00:00 [kintegrityd]
root        23     2  0 Nov08 ?        00:00:00 [bioset]
root        24     2  0 Nov08 ?        00:00:00 [kblockd]
root        25     2  0 Nov08 ?        00:00:00 [md]
root        26     2  0 Nov08 ?        00:00:00 [edac-poller]
root        32     2  0 Nov08 ?        00:00:00 [kswapd0]
root        33     2  0 Nov08 ?        00:00:00 [ksmd]
root        34     2  0 Nov08 ?        00:00:01 [khugepaged]
root        35     2  0 Nov08 ?        00:00:00 [crypto]
root        43     2  0 Nov08 ?        00:00:00 [kthrotld]
root        45     2  0 Nov08 ?        00:00:00 [kmpath_rdacd]
root        46     2  0 Nov08 ?        00:00:00 [kaluad]
root        48     2  0 Nov08 ?        00:00:00 [kpsmoused]
root        62     2  0 Nov08 ?        00:00:00 [deferwq]
root        92     2  0 Nov08 ?        00:00:01 [kauditd]
root       228     2  0 Nov08 ?        00:00:00 [scsi_eh_0]
root       229     2  0 Nov08 ?        00:00:00 [ata_sff]
root       230     2  0 Nov08 ?        00:00:00 [scsi_tmf_0]
root       231     2  0 Nov08 ?        00:00:00 [scsi_eh_1]
root       232     2  0 Nov08 ?        00:00:00 [scsi_tmf_1]
root       233     2  0 Nov08 ?        00:00:00 [scsi_eh_2]
root       234     2  0 Nov08 ?        00:00:00 [scsi_tmf_2]
root       237     2  0 Nov08 ?        00:00:00 [vmw_pvscsi_wq_0]
root       241     2  0 Nov08 ?        00:00:00 [scsi_eh_3]
root       242     2  0 Nov08 ?        00:00:00 [scsi_tmf_3]
root       243     2  0 Nov08 ?        00:00:00 [scsi_eh_4]
root       244     2  0 Nov08 ?        00:00:00 [scsi_tmf_4]
root       245     2  0 Nov08 ?        00:00:00 [scsi_eh_5]
root       246     2  0 Nov08 ?        00:00:00 [scsi_tmf_5]
root       247     2  0 Nov08 ?        00:00:00 [scsi_eh_6]
root       248     2  0 Nov08 ?        00:00:00 [scsi_tmf_6]
root       249     2  0 Nov08 ?        00:00:00 [scsi_eh_7]
root       250     2  0 Nov08 ?        00:00:00 [scsi_tmf_7]
root       251     2  0 Nov08 ?        00:00:00 [scsi_eh_8]
root       252     2  0 Nov08 ?        00:00:00 [scsi_tmf_8]
root       253     2  0 Nov08 ?        00:00:00 [scsi_eh_9]
root       254     2  0 Nov08 ?        00:00:00 [scsi_tmf_9]
root       255     2  0 Nov08 ?        00:00:00 [scsi_eh_10]
root       256     2  0 Nov08 ?        00:00:00 [scsi_tmf_10]
root       257     2  0 Nov08 ?        00:00:00 [scsi_eh_11]
root       258     2  0 Nov08 ?        00:00:00 [scsi_tmf_11]
root       259     2  0 Nov08 ?        00:00:00 [scsi_eh_12]
root       260     2  0 Nov08 ?        00:00:00 [scsi_tmf_12]
root       261     2  0 Nov08 ?        00:00:00 [scsi_eh_13]
root       262     2  0 Nov08 ?        00:00:00 [scsi_tmf_13]
root       263     2  0 Nov08 ?        00:00:00 [scsi_eh_14]
root       264     2  0 Nov08 ?        00:00:00 [scsi_tmf_14]
root       265     2  0 Nov08 ?        00:00:00 [scsi_eh_15]
root       266     2  0 Nov08 ?        00:00:00 [scsi_tmf_15]
root       267     2  0 Nov08 ?        00:00:00 [scsi_eh_16]
root       268     2  0 Nov08 ?        00:00:00 [scsi_tmf_16]
root       269     2  0 Nov08 ?        00:00:00 [scsi_eh_17]
root       270     2  0 Nov08 ?        00:00:00 [scsi_tmf_17]
root       271     2  0 Nov08 ?        00:00:00 [scsi_eh_18]
root       272     2  0 Nov08 ?        00:00:00 [scsi_tmf_18]
root       273     2  0 Nov08 ?        00:00:00 [scsi_eh_19]
root       274     2  0 Nov08 ?        00:00:00 [scsi_tmf_19]
root       275     2  0 Nov08 ?        00:00:00 [scsi_eh_20]
root       276     2  0 Nov08 ?        00:00:00 [scsi_tmf_20]
root       277     2  0 Nov08 ?        00:00:00 [scsi_eh_21]
root       278     2  0 Nov08 ?        00:00:00 [scsi_tmf_21]
root       279     2  0 Nov08 ?        00:00:00 [scsi_eh_22]
root       280     2  0 Nov08 ?        00:00:00 [scsi_tmf_22]
root       281     2  0 Nov08 ?        00:00:00 [scsi_eh_23]
root       282     2  0 Nov08 ?        00:00:00 [scsi_tmf_23]
root       283     2  0 Nov08 ?        00:00:00 [scsi_eh_24]
root       284     2  0 Nov08 ?        00:00:00 [scsi_tmf_24]
root       285     2  0 Nov08 ?        00:00:00 [scsi_eh_25]
root       286     2  0 Nov08 ?        00:00:00 [scsi_tmf_25]
root       287     2  0 Nov08 ?        00:00:00 [scsi_eh_26]
root       288     2  0 Nov08 ?        00:00:00 [scsi_tmf_26]
root       289     2  0 Nov08 ?        00:00:00 [scsi_eh_27]
root       290     2  0 Nov08 ?        00:00:00 [scsi_tmf_27]
root       291     2  0 Nov08 ?        00:00:00 [scsi_eh_28]
root       292     2  0 Nov08 ?        00:00:00 [scsi_tmf_28]
root       293     2  0 Nov08 ?        00:00:00 [scsi_eh_29]
root       294     2  0 Nov08 ?        00:00:00 [scsi_tmf_29]
root       295     2  0 Nov08 ?        00:00:00 [scsi_eh_30]
root       296     2  0 Nov08 ?        00:00:00 [scsi_tmf_30]
root       297     2  0 Nov08 ?        00:00:00 [scsi_eh_31]
root       299     2  0 Nov08 ?        00:00:00 [scsi_tmf_31]
root       300     2  0 Nov08 ?        00:00:00 [scsi_eh_32]
root       301     2  0 Nov08 ?        00:00:00 [scsi_tmf_32]
root       372     2  0 Nov08 ?        00:00:01 [kworker/0:1H]
root       424     2  0 Nov08 ?        00:00:00 [kdmflush]
root       425     2  0 Nov08 ?        00:00:00 [bioset]
root       435     2  0 Nov08 ?        00:00:00 [kdmflush]
root       436     2  0 Nov08 ?        00:00:00 [bioset]
root       450     2  0 Nov08 ?        00:00:00 [jbd2/dm-0-8]
root       451     2  0 Nov08 ?        00:00:00 [ext4-rsv-conver]
root       480     2  0 Nov08 ?        00:00:10 [jbd2/dm-1-8]
root       481     2  0 Nov08 ?        00:00:00 [ext4-rsv-conver]
root       513     1  0 Nov08 ?        00:01:08 /usr/lib/systemd/systemd-journald
root       540     1  0 Nov08 ?        00:00:00 /usr/lib/systemd/systemd-udevd
root       541     1  0 Nov08 ?        00:00:00 /usr/sbin/lvmetad -f
root       560     2  0 Nov08 ?        00:00:00 [ttm_swap]
root       561     2  0 Nov08 ?        00:00:00 [irq/16-vmwgfx]
root       565     2  0 Nov08 ?        00:00:00 [nfit]
root       644     2  0 Nov08 ?        00:00:00 [bioset]
root       645     2  0 Nov08 ?        00:00:00 [xfsalloc]
root       646     2  0 Nov08 ?        00:00:00 [xfs_mru_cache]
root       647     2  0 Nov08 ?        00:00:00 [xfs-buf/sda1]
root       648     2  0 Nov08 ?        00:00:00 [xfs-data/sda1]
root       649     2  0 Nov08 ?        00:00:00 [xfs-conv/sda1]
root       650     2  0 Nov08 ?        00:00:00 [xfs-cil/sda1]
root       651     2  0 Nov08 ?        00:00:00 [xfs-reclaim/sda]
root       652     2  0 Nov08 ?        00:00:00 [xfs-log/sda1]
root       653     2  0 Nov08 ?        00:00:00 [xfs-eofblocks/s]
root       654     2  0 Nov08 ?        00:00:00 [xfsaild/sda1]
root       656     2  0 Nov08 ?        00:00:00 [kdmflush]
root       657     2  0 Nov08 ?        00:00:00 [bioset]
root       658     2  0 Nov08 ?        00:00:00 [kdmflush]
root       660     2  0 Nov08 ?        00:00:00 [bioset]
root       661     2  0 Nov08 ?        00:00:00 [kdmflush]
root       663     2  0 Nov08 ?        00:00:00 [bioset]
root       665     2  0 Nov08 ?        00:00:00 [kdmflush]
root       668     2  0 Nov08 ?        00:00:00 [bioset]
root       671     2  0 Nov08 ?        00:00:00 [kdmflush]
root       672     2  0 Nov08 ?        00:00:00 [bioset]
root       698     2  0 Nov08 ?        00:00:00 [jbd2/dm-5-8]
root       699     2  0 Nov08 ?        00:00:00 [ext4-rsv-conver]
root       702     2  0 Nov08 ?        00:00:10 [jbd2/dm-6-8]
root       704     2  0 Nov08 ?        00:00:00 [ext4-rsv-conver]
root       714     2  0 Nov08 ?        00:00:00 [jbd2/dm-4-8]
root       715     2  0 Nov08 ?        00:00:00 [ext4-rsv-conver]
root       724     2  0 Nov08 ?        00:00:00 [jbd2/dm-3-8]
root       725     2  0 Nov08 ?        00:00:00 [ext4-rsv-conver]
root       727     2  0 Nov08 ?        00:00:00 [jbd2/dm-2-8]
root       728     2  0 Nov08 ?        00:00:00 [ext4-rsv-conver]
root       734     1  0 Nov08 ?        00:00:05 /sbin/auditd
polkitd    758     1  0 Nov08 ?        00:00:03 /usr/lib/polkit-1/polkitd --no-debug
dbus       759     1  0 Nov08 ?        00:00:21 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
root       765     1  0 Nov08 ?        00:00:00 /usr/bin/VGAuthService -s
root       766     1  0 Nov08 ?        00:05:29 /usr/bin/vmtoolsd
root       768     1  0 Nov08 ?        00:00:00 /usr/sbin/smartd -n -q never
root       769     1  0 Nov08 ?        00:00:21 /usr/sbin/irqbalance --foreground
root       776     1  0 Nov08 ?        00:00:08 /usr/lib/systemd/systemd-logind
root       783     1  0 Nov08 ?        00:00:00 /usr/sbin/gpm -m /dev/input/mice -t exps2
root       786     1  0 Nov08 ?        00:00:21 /usr/sbin/crond -n
root       790     1  0 Nov08 ?        00:00:00 /usr/sbin/atd -f
chrony     806     1  0 Nov08 ?        00:00:01 /usr/sbin/chronyd
root       841     2  0 Nov08 ?        00:00:00 [kworker/1:1H]
root       988     1  0 Nov08 ?        00:00:21 /usr/sbin/httpd -DFOREGROUND
root       991     1  0 Nov08 ?        00:13:58 python /usr/bin/goferd --foreground
root       994     1  0 Nov08 ?        00:00:52 /usr/sbin/rsyslogd -n
root      1005     1  0 Nov08 ?        00:00:00 /usr/sbin/sshd -D
root      1007     1  0 Nov08 ?        00:00:48 /usr/bin/python -Es /usr/sbin/tuned -l -P
root      1008     1  0 Nov08 ?        00:00:00 /usr/bin/rhsmcertd
root      1011     1  0 Nov08 ?        00:00:00 /usr/sbin/xinetd -stayalive -pidfile /var/run/xinetd.pid
mysql     1091     1  0 Nov08 ?        00:00:00 /bin/sh /usr/bin/mysqld_safe --basedir=/usr
mysql     1419  1091  0 Nov08 ?        00:08:09 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/plugin --log-error=/var/log/mariadb/mariadb.log --pid-file=/var/run/mariadb/mariadb.pid --socket=/var/lib/mysql/mysql.sock
root      1504     1  0 Nov08 ?        00:00:03 /usr/libexec/postfix/master -w
postfix   1515  1504  0 Nov08 ?        00:00:01 qmgr -l -t unix -u
nagios    1551     1  0 Nov08 ?        00:00:00 /usr/local/ncpa/ncpa_listener --start
nagios    1553     1  0 Nov08 ?        00:01:11 /usr/local/ncpa/ncpa_passive --start
nagios    1557     1  0 Nov08 ?        00:00:30 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
ajaxterm  1575     1  0 Nov08 ?        00:02:14 python /usr/share/ajaxterm/ajaxterm.py --daemon --port=8022 --uid=ajaxterm
root      1735     1  0 Nov08 tty1     00:00:00 /sbin/agetty --noclear tty1 linux
root      8313     2  0 07:05 ?        00:00:00 [kworker/0:2]
nagios    8672     1  0 Nov08 ?        00:00:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg -f
nagios    8719     1  0 Nov08 ?        00:01:11 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios    8721  8719  0 Nov08 ?        00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios    8722  8719  0 Nov08 ?        00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios    8723  8719  0 Nov08 ?        00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios    8724  8719  0 Nov08 ?        00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios    8728  8672  0 Nov08 ?        00:00:08 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg -f
nagios    8729  8728  0 Nov08 ?        00:00:51 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg -f
nagios    8782  8719  0 Nov08 ?        00:00:28 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root     12760     2  0 07:50 ?        00:00:00 [kworker/1:0]
root     15820     2  0 08:20 ?        00:00:00 [kworker/u128:0]
root     15948     2  0 08:21 ?        00:00:00 [kworker/1:2]
postfix  16295  1504  0 08:25 ?        00:00:00 pickup -l -t unix -u
root     16297     2  0 08:25 ?        00:00:00 [kworker/0:0]
root     16298     2  0 08:25 ?        00:00:00 [kworker/u128:2]
apache   16869   988  0 08:29 ?        00:00:00 /usr/sbin/httpd -DFOREGROUND
root     16884  1005  0 08:29 ?        00:00:00 sshd: admin [priv]
admin    16888 16884  0 08:29 ?        00:00:00 sshd: admin@pts/0
root     16889  1005  0 08:29 ?        00:00:00 sshd: admin [priv]
admin    16893 16889  0 08:29 ?        00:00:00 sshd: admin@notty
admin    16894 16893  0 08:29 ?        00:00:00 /usr/libexec/openssh/sftp-server
admin    16910 16888  0 08:29 pts/0    00:00:00 -bash
root     16949 16910  0 08:29 pts/0    00:00:00 sudo -s
root     16953 16949  0 08:29 pts/0    00:00:00 /bin/bash
root     17054     2  0 08:30 ?        00:00:00 [kworker/1:1]
root     17238     2  0 08:31 ?        00:00:00 [kworker/u128:1]
root     17243 16953  0 08:31 pts/0    00:00:00 ps -ef --cols=300
apache   18366   988  0 Nov12 ?        00:00:03 /usr/sbin/httpd -DFOREGROUND
apache   19233   988  0 Nov12 ?        00:00:00 /usr/sbin/httpd -DFOREGROUND
apache   46956   988  0 Nov12 ?        00:01:23 /usr/sbin/httpd -DFOREGROUND
apache   46995   988  0 Nov12 ?        00:00:50 /usr/sbin/httpd -DFOREGROUND
apache   49119   988  0 Nov12 ?        00:01:16 /usr/sbin/httpd -DFOREGROUND
apache   56307   988  0 Nov12 ?        00:00:27 /usr/sbin/httpd -DFOREGROUND
apache   56926   988  0 Nov12 ?        00:00:26 /usr/sbin/httpd -DFOREGROUND
apache   57523   988  0 Nov12 ?        00:00:37 /usr/sbin/httpd -DFOREGROUND
apache   61472   988  0 Nov12 ?        00:00:17 /usr/sbin/httpd -DFOREGROUND
For every command I submit through the Nagios XI interface I get the following error :
And systat shows :
Regards.
One thing I see is that the cron daemon is not running the processes that Nagios needs to run so to start them, login as root and run this command.
service crond stop
killall -9 crond
To see if they are running, wait a few minutes and run this.
ps -ef |grep cron
You should see something similar to this.
nagios    5908  5904  0 08:26 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1
nagios    5911  5906  0 08:26 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1
nagios    5912  5903  0 08:26 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1
nagios    5913  5902  0 08:26 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1
nagios    5914  5905  0 08:26 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1
nagios    5916  5907  0 08:26 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1
nagios    5917  5908  0 08:26 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php
nagios    5922  5911  0 08:26 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php
nagios    5923  5912  0 08:26 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php
nagios    5924  5913  0 08:26 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php
nagios    5925  5914  0 08:26 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php
nagios    5927  5916  0 08:26 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php
nagios    8076  8063  0 Nov09 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1
nagios    8086  8076  0 Nov09 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php
nagios    9131  9128  0 Nov09 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1
If not, then something is not allowing the cron daemon to run. Usually it is a security policy.
Check the cron logs by running the following and posting the output here.
tail -50 /var/log/cron
Next is the missing nagios.lock file.
To fix this, we will need to know which version of XI that is installed and the following 2 files from the server uploaded to the post.
/etc/init.d/nagios
Thanks.
