Soft service recoveries being logged as hard
crystal.then
Post by crystal.then »
We're having an issue after upgrading from Nagios XI 5.4.8 to 5.5.3. Soft recoveries are being logged as hard recoveries -
This is affecting the "top alert producers" report, which appears to look for hard state changes.
Is this a known issue? Or have I gone wrong with a config item somewhere?
(The service check timing out is a separate issue, which we're looking in to)
Cheers!
Re: Soft service recoveries being logged as hard
This is a Nagios Core bug (https://github.com/NagiosEnterprises/na ... issues/575) that has been fixed in the maintenance branch, and the fix will be included in Nagios XI 5.5.7, which should l be released sometime next week.
crystal.then
Thanks! Will update when it's available
Sure. Let us know if the update fixes your issue.
