Good morning,
can we draw in nagvis a frame (container) that takes the same color as a server state (green when the server is up, red when the server is down, etc.) if yes, can you explaine me how.
Thank you very much
relation between nagios and nagvis
jaouadovsky
- Capturef2.PNG (26.71 KiB) Viewed 846 times
Re: relation between nagios and nagvis
This doesn't appear to be an option in the Nagvis version that is in XI but you may have better luck on newer versions. Nagvis is a third party tool that we do not develop so you may have better luck finding an answer on their forums - https://www.nagvis.org/free-support
