Memory used greater than allocated RAM capacity.
technosol
Post by technosol »
Hi
I have a nls 2-node cluster with 32GB RAM for each nls. As I checked, Under Admin -->Instance status, used mem has been more than 32 GB. Please see the attached screenshot.
Can you please help me to understand it?
Thank you
Re: Memory used greater than allocated RAM capacity.
Post by mcapra »
My memory may be failing me, but I'm *pretty sure* those stats are cluster-level, evaluated by hitting the _cluster/stats endpoint of the ElasticSearch API and evaluating the os section of the returned result. The measurements represent the combined resources of all nodes in the cluster.
There is also a _node/stats endpoint which does roughly the same thing, but for an individual node.
cdienger
Post by cdienger »
Awesome memory, @mcapa!
It's making a call to _cluster/stats?human and then extracting from nodes > os > memory > total.
