Google Map not displaying host
Fred Kroeger
Post by Fred Kroeger »
Have installed the Google Map component as per the Google Map Integration PDF. Upgraded to latest version v1.6.0.
Got the API Key & Updated the PHP file as per the doco. Set up the Lat/Long for a host in the Notes field as per the doco. However the host doesn't display on the Google map. I tried selecting the individual host only on the Google Map screen (it's the only one configured and the only one I could select) - I tried zooming out in case the pin was showing elsewhere in the world - it is not shown at all. Running the latest NagioXI v5.5.6
Regards... Fred
npolovenko
Re: Google Map not displaying host
Post by npolovenko »
Hello, @Fred Kroeger. What OS is this XI installed on? Is this a new install or you upgraded from an older version? Can you send me a screenshot of the host coordinates in the notes field? I'll try to replicate your problem.
Fred Kroeger
Brand new VM install - NagiosXI 5.5.6. Requested screen shots attached
Also should have mentioned that I added the API Key as well via the Google Map Settings in the Manage Components screen.
The coords entered were taken from the Google Map "Get geocode for an address" link
npolovenko
@Fred Kroeger, Thank you. I was able to catch the error. Looks like Google Maps changed their API a little bit so we made a minor change to the component. Please navigate to the components menu in XI, delete the old google maps component and install the attached zip instead.
Fred Kroeger
Brilliant - Displays as expected now.
Thanks .... Fred
I am glad your issue has been resolved! I am closing this topic.
