SNMP switch uptime using SNMP walk
cyxitnetwork
Creating SNMP uptime sensor using the "SNMP Walk" configuration wizard shows the uptime during the SNMP walk as seen below in SNMP test, however once added the service shows up as critical and not uptime data is available as seen in Snmp test1.
Re: SNMP switch uptime using SNMP walk
Trying using a plugin like https://exchange.nagios.org/directory/P ... me/details to return the uptime in days, hours, minutes, etc.
cyxitnetwork
@cdienger Thanks will try that. I was hoping the SNMP Walk configuration wizard would be a much straightforward approach since it's already integrated with Nagios XI.
cyxitnetwork
SNMP uptime plugin worked.
Glad to hear!
