Trying to install Nagios Log Server recieve the following error for new Redhat install.
The step that failed was: 'prereqs'
Nagios Log Server Installation
DATE: Tue Nov 13 15:43:14 CET 2018
DISTRO INFO:
RedHatEnterpriseServer
7.4
x86_64
Running 'setup_local_syslog'...
setup_local_syslog step completed OK
Running 'prereqs'...
Enabling epel repo...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
curl: (60) Peer's certificate issuer has been marked as not trusted by the user.
More details here: http://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
Nagios Log Server Installer
Copyright 2014-2018, Nagios Enterprises LLC.
License:
Nagios Software License <http://assets.nagios.com/licenses/nagio ... icense.txt>
Usage: ./fullinstall [options...]
Options:
-h | --help
Display this help text
-a | --add_node
-m | --master
-i | --id
-n | --non-interactive
Assume defaults for all questions (for scripted installs)
ERROR: invalid command line syntax.
DATE: Tue Nov 13 15:47:32 CET 2018
DISTRO INFO:
7.4
x86_64
setup_local_syslog step already completed - skipping
INSTALLATION ERROR!
npolovenko
- Support Tech
Re: The step that failed was: 'prereqs'
@delwins, You have a problem with the CURL command:
https://access.redhat.com/solutions/3034501
Please go over the following article and let me know if it fixes your issue:curl: (60) Peer's certificate issuer has been marked as not trusted by the user.
