Active checks stuck every day at same time
pdusza
Post by pdusza »
From about three days I have a strange issue with nagiosXI. At about 1 am almost all active checks and performance graph stuck. What is really interesting 'Next check' date is set to another day at midnight. The only thing which I can do is to schedule immediate check on all host and services.
Some hosts/services are ok (updated and checked) but most of them just stuck. I checked the npcd logs, nagios logs and I don't see there any errors, NPCD deamon is running. There is no differences between hosts/services definition of those which stuck and running (same templates).
I have no idea what could be wrong.
Please look at screens:
mguthrie
Re: Active checks stuck every day at same time
Post by mguthrie »
That is pretty odd. Can you show us the output from the following command?
chage -l nagios
First, lets make sure we don't have multiple instances of Nagios that have spawned. Run the following from the command-line:
service nagios stop
killall -9 nagios
service nagios start
Then lets check to make sure there isn't any DB corruption:
http://assets.nagios.com/downloads/nagi ... tabase.pdf
pdusza
Post by pdusza »
here is a output of that commands:
and here is an output of repairing process (no errors):
result.txt
