Query monitoring EMC VNX
alex3105
Post by alex3105 »
Good afternoon,
I am trying to monitor an EMC VNX5200 device using the plugin of the following link:
https://exchange.nagios.org/directory/P ... 74/details
Through the interface of Centos 7 I can validate correctly when I execute the commands with the plugin:
check_emc_clariion.pl -H 192.168.5.1 -u readonly -p AStrongPassword -t disk
The array is operating normally
check_emc_clariion.pl -H 192.168.5.1 -u readonly -p AStrongPassword -t faults
80 physical disks are Ok. Hostpares are ready
But in the web interface of nagios it appears with errors as the attachment. Additionally, I have doubts about the definition of the equipment since it has two controllers, each with a different ip (SPA and SPB)
This is content of the file commands.cfg:
command_name check_emc_clariion
command_line $USER1$/check_emc_clariion.pl -H $ARG1$ $ARG2$ $ARG3$ $ARG4$ $ARG5$ $ARG6$ $ARG7$ $ARG8$
Grateful for the support,
Regards
san.cfg
(1.54 KiB) Downloaded 439 times
cdienger
Re: Query monitoring EMC VNX
Post by cdienger »
How strong is "AStrongPassword" ? Does it contain any special characters like |,$,!, etc.. ? Can you test with ASlightlyWeakerPasswordthat doesn't have any special characters?
alex3105
Post by alex3105 »
Dear cdienger, I have also tried with the credentials by default user and password sysadmin.
cdienger
Post by cdienger »
Try switching to the nagios user and then running the ocmmands from the ocmmand line:
su - nagios
Also check the permissions on /opt/Navisphere/bin/navicli to verify that the nagios user is able to execute it.
alex3105
Post by alex3105 »
Executing the commands from the user nagios appears:
[nagios@localhost libexec]$ ./check_emc_clariion.pl -H 192.168.5.1 -u sysadmin -p sysadmin -t faults
Error occurred during HTTP request/response from the target: '192.168.5.1'.
Unable to validate the identity of the server. There are issues with the certificate presented.
Only import this certificate if you have reason to believe it was sent by a trusted source.
Certificate details:
Subject: CN=192.168.5.1,CN=B-IMAGE,OU=CLARiiON
Issuer: CN=192.168.5.1,CN=B-IMAGE,OU=CLARiiON
Serial#: f0512c00
Valid From: 20141231212225Z
Valid To: 20191230212225Z
Would you like to [1]Accept the certificate for this session, [2] Accept and store, [3] Reject the certificate?
Please input your selection(The default selection is [1]):
The array is operating normally.
Also, I do not have the navicli folder ..
[root@localhost libexec]# ll /opt/Navisphere/bin/
total 15212
-rwxrwxr-x 1 root root 562895 feb 26 2016 admsnap
-rwxrwxr-x 1 root root 15002779 feb 26 2016 naviseccli
-rwxr-xr-x 1 root root 3945 feb 26 2016 setlevel_cli.sh
-rw-r--r-- 1 root root 7 oct 17 15:21 setlevel.log
Your first post you show you show a different username and password then the last post, can you verify that they are correct?
cdienger
Post by cdienger »
Also, try running the command both as nagios and as root:
/opt/Navisphere/bin/naviseccli security -certificate -getLevel
It looks like the problem is that the certificate isn't trusted. You may need to use the naviseccli to add a cert or adjust the level:
/opt/Navisphere/bin/naviseccli security -certificate -setLevel low
alex3105
Post by alex3105 »
Dear tgriep, The user who has access is by default: sysadmin
Dear cdienger: Executing the command as user nagios and root results in a medium level.
But when trying to assign a low level I get
Cannot write into /opt/Navisphere/seccli/CST/certConfig.security/.
Permission denied. Caller not privileged
Cannot write encrypted_user info to the security file
It is not an editable file, how can I assign it the low level ..?
cdienger
Post by cdienger »
If the command returns Medium for both nagiso and root then I think that setting can be ignored. Try running this instead as nagios:
and when it prompts:
select option [2] and then again run:
alex3105
Post by alex3105 »
As a nagios user I have returned to execute the command but I get the result the option to add the certificate does not appear
The array is operating normally..
but the option to add certificate does not appear..
as a nagios user I have executed:
Add naviseccli bin directory, which is usually /opt/Navisphere/bin, to your system PATH. For example, add the following
line to ~/.bash_profile & ~/.bashrc and then execute this file to make the setting effective by running source ~/.bash_profile
or source ~/.bashrc.
PATH=$PATH:/opt/Navisphere/bin
export PATH
naviseccli -user usename -password password -h sp_ip -scope 0 -np getagent
get data from my SAN but I can not add the certificate again.
