Error: Can't locate perl510.dll
kwhogster
Post by kwhogster »
Nagios Core 4.3.4
Nsclient 4.3
Windows 10
Just restarted my Windows 10 Desktop VM and Nagios reports this warning on two checks
Check Windows Temp Folder WARNING 11-14-2018 22:01:47 0d 0h 32m 58s 10/10 Error: Can't locate perl510.dll
Explorer WARNING 11-14-2018 22:28:58 0d 0h 33m 34s 20/20 Error: Can't locate perl510.dll
Any ideas?
benjaminsmith
Re: Error: Can't locate perl510.dll
Post by benjaminsmith »
Hi @kwhogster,
It's most likely a corrupt file or perhaps another program overwrote/deleted this file. Have you made any changes/installed new software since this problem started or is it possible to revert to previous VM snapshot?
1. What version of perl do you have installed?
2. What plugin within Nagios are you using for those checks?
kwhogster
Post by kwhogster »
Hello
No Perl installed on this desktop
My code
        host_name               hostname
        service_description     Explorer
        check_command           check_nrpe!check_explorer! -a explorer.exe
        servicegroups           explorer
        host_name               hostname
        service_description     Check Windows Temp Folder
        check_command           check_winfile
        servicegroups           Windows Temp
        check_interval          60
        notification_interval   60
        command_name    check_winfile
        command_line    $USER1$/check_nrpe -H $HOSTADDRESS$ -t 120 -c check_winfile -a '--target c:\windows\temp --filter "size gt 1073741824" -delete'
        command_name    check_explorer
        command_line    $USER1$/check_procs -c 1:30 -C explorer
Ran sfc /scannow came back clean
I search for perl510.dll on another windows 10 desktop that has the exact same checks above and they work on that one. and the dll is not found anywhere on the one either.
benjaminsmith
Hello kwhogster,
If these checks are working fine on the other Windows 10 systems, then I would compare the nsclient.ini file with those other systems. Double check the ini file for the correct check_winfile definition in the external scripts settings. Make sure the script exists on you this Windows system.
Also, can you review (or post) the nsclient.log file for errors.
Let me know if you get it resolved.
Configuring The Windows Agent: NSClient++
kwhogster
Post by kwhogster »
checked both nsclient.ini files they look the same
The files reside on both in the same folder.
On the problem computer I ran the command manually
C:\Program Files\NSClient++\scripts>check_winprocess
PROCESS OK - 119 process(es)|processes=119;;;
My nsclient log in the log do not see any problems with current dates. check_schtask was the only one I see and I fixed that recently.
nsclient.log
nsclient log
(50.63 KiB) Downloaded 393 times
kwhogster
Post by kwhogster »
Hi
I think i got it working now.
I installed activeperl 64 bit from perl.org site.
Then after a restarted the checks cleared and are working.
This was very strange and is still not explained.
We can lock this for now
benjaminsmith
Hello @kwhogster
I think i got it working now ......We can lock this for now
Glad you got it resolved. I will go a head lock this topic. Thank you for using Nagios.
