I'm doing some testing of transferring snapshot "logstash" data from one system to another and have the following scenario:
1. Fresh install of Nagios (https://www.nagios.com/downloads/nagios ... er/vmware/) in a Virtual machine (completely isolated from the rest of the network)
2. Working Cluster install of Nagios with a few TB of data.
I wish to transfer a single snapshot file representing a 24hr period from (2) above, to the fresh install of Nagios and restore the data to that instance.
As an example I copy the directory "logstash-2018.09.28" from the Cluster install to the "usr/repository/indices' directory on the VM. However the "Index Status"
page in the Nagios LogServer web interface never lists this particular snapshot so I cannot restore it to that instance.
What files/procedure should I follow as a minimum to get this working please? I have read over the following two PDFs but must be overlooking something obvious
and would appreciate any input you can provide into this please.
https://assets.nagios.com/downloads/nag ... Server.pdf
https://assets.nagios.com/downloads/nag ... enance.pdf
Transferring Snapshot "logstash"
Re: Transferring Snapshot "logstash"
What you need to do is setup the new Log Server to be able to access the repository (mount snapshot repository) then add repository to Admin -> Snapshots & Maintenance
then you should be able to restore the index through the Web UI
