Nagios XI monitoring Engine dies after apply config
aeckland1
Post by aeckland1 »
When we apply the config in CCM the monitoring engine failes to start. On the command line it failes to start as well. I can get it to start if I stop ndo2db then start the monitoring engine. The preflight runs through with no errors. This system is running 3000 service checks and 300 hosts, the DB is on a separate host. Running Nagios core 4.4.2 and Xiamen 5.5.3. I have looked at this for about a day also rebuilt the server an I’m still seeing the same issue. Any help would be appreciated.
August
benjaminsmith
Re: Nagios XI monitoring Engine dies after apply config
Post by benjaminsmith »
Hi August,
It's possible you have some crashed database tables. Depending on which database, please check the log files for error messages:
/var/log/mariadb/mariadb.log
/var/log/mysqld.log
If you have any error messages related to crashed tables, run the repair script:
service mysqld stop
/usr/local/nagiosxi/scripts/repairmysql.sh nagios
service mysqld start
Repairing the Nagios XI Database
https://assets.nagios.com/downloads/nag ... tabase.pdf
If this is not the issue, then please send us a system profile so we can take a closer look at your logs.
To send us your system profile. Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and upload it to a cloud storage of your choice. You can share a link with me in a personal message.
After you upload the profile please post something in this thread to bring it up in the support queue.
aeckland1
Post by aeckland1 »
There were no error in the db logs, so I will send over the profile link in a personal message.
- August
benjaminsmith
Hi August,
We took a look at your profile. Let's try to log in as nagios and run the re-configure script. Also, did you recently upgrade to a new version? If so, what version did you upgrade from?
1. Login as Nagios
su - nagiossu
2. Run the re-configure script
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
If you're still having trouble, run the pre-flight check again and let us know if you get any errors. Also, it looks like the database is on another server, can you post the log file for us to review? Thanks.
Pre-flight Configuration Check:
aeckland1
Post by aeckland1 »
Still no luck see below:
Also this is a fresh install.
bash-4.2$ service nagios status
Redirecting to /bin/systemctl status nagios.service
● nagios.service - Nagios Core 4.4.2
   Loaded: loaded (/usr/lib/systemd/system/nagios.service; enabled; vendor preset: disabled)
   Active: failed (Result: exit-code) since Tue 2018-11-20 15:11:54 PST; 8min ago
     Docs: https://www.nagios.org/documentation
  Process: 11916 ExecStopPost=/bin/rm -f /usr/local/nagios/var/rw/nagios.cmd (code=exited, status=0/SUCCESS)
  Process: 11873 ExecStop=/bin/kill -s TERM ${MAINPID} (code=exited, status=1/FAILURE)
  Process: 11841 ExecStart=/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
  Process: 11839 ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
 Main PID: 11843 (code=killed, signal=ABRT)
bash-4.2$ /usr/local/nagiosxi/scripts/reconfigure_nagios.sh
--- reset_config_perms.sh ------------
> Setting CCM script permissions
> Setting script permissions
> Setting special component script permissions
> Setting configuration file/directory permissions
> Setting perfdata directory and RRD permissions
> Setting NOM checkpoint user:group permissions
> + Setting CCM configuration file user:group permissions
> + Setting Recurring Downtime file user:group permissions
> + Setting BPI configuration file user:group permissions
--- ccm_import.php -------------------
> Setting import directory: /usr/local/nagios/etc/import/
> Importing config files into the CCM
  No files to import
--- ccm_export.php -------------------
> Writing CCM configuration to Nagios files
  Finished writing out configuraton
> Verifying configuration with Nagios Core
> Output:
Nagios Core 4.4.2
Last Modified: 2018-08-16
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
        Checked 2864 services.
        Checked 360 hosts.
        Checked 30 host groups.
        Checked 4 service groups.
        Checked 14 contacts.
        Checked 12 contact groups.
        Checked 171 commands.
        Checked 10 time periods.
        Checked 145 host escalations.
        Checked 1388 service escalations.
        Checked 360 hosts
        Checked 3432 service dependencies
        Checked 0 host dependencies
        Checked 10 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
> Return Code: 0
   Active: failed (Result: exit-code) since Tue 2018-11-20 15:20:08 PST; 974ms ago
  Process: 14355 ExecStopPost=/bin/rm -f /usr/local/nagios/var/rw/nagios.cmd (code=exited, status=0/SUCCESS)
  Process: 14320 ExecStop=/bin/kill -s TERM ${MAINPID} (code=exited, status=1/FAILURE)
  Process: 14277 ExecStart=/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
  Process: 14275 ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
 Main PID: 14279 (code=killed, signal=ABRT)
Can you PM me your profile (profile.zip)?
Admin > System Config > System Profile > Download Profile
Also, PM me that /etc/init.d/nagios and /lib/systemd/system/nagios.service, whichever exists on your system. Thanks!
aeckland1
Post by aeckland1 »
Sent request info over, Thanks
benjaminsmith
Hi August,
I believe we have an issue with the nagios.lock file path. Please make a backup, and if you are using a VM take a snapshot.
1. Please verify that you do not have the older nagios startup script at: /etc/init.d/nagios
ls /etc/init.d/nagios
If not, stop Nagios and remove the lock file:
service nagios stop
service ndo2db stop
rm -f  /var/run/nagios.lock
Change the lock file path in /usr/local/nagios/etc/nagios.cfg
lock_file=/var/run/nagios.lock
CHANGE TO:
lock_file = /usr/local/nagios/var/nagios.lock
Restart Nagios
service ndo2db start
service nagios start
If this does not correct the issue, please open a support ticket and we may schedule a remote session to correct the problem.
Backing Up Nagios Xi
aeckland1
Post by aeckland1 »
This did not work, opening a support ticket
benjaminsmith
OK. I will go head and close this topic.
