SSH Backup
psasines
SSH Backup
Post by psasines »
Hi all,
I have the payed version with support active but cannot create a new post on that section.
I am trying to perform backups via SSH to another server.
I have setup everything with my details and when testing the connection i get this information: "Connection established. Username/Password OK."
When i try to test SCP transfer i am getting this error: "Could not transfer file. Permissions may be wrong or folder may not exist."
I have tested using another client with the same credentials and am able to create and delete files and folders.
I have just now created a local FTP server but have the same result, can authenticate but cannot perform the test upload.
Via command line from Nagios server, i am able to upload a file to the SCP server without any problems.
How can i troubleshoot this issue?
Thanks in advance.
Kind regards,
Rodrigo Catarino
Re: SSH Backup
closing as a duplicate of this thread
https://support.nagios.com/forum/viewto ... =6&t=51303
