Fix for vulnerability
lrnnetops
Post by lrnnetops »
Hi Team,
Our security team has reported vulnerability for installed Nagios Xi version (5.4.8). we are in the process of upgrading our instance to latest version.
Please find attached file "
NagiosXI_vulnerability.csv
" for vulnerability details & suggest the fix.
Regards,
Rohan Talkar
lrnnetops
Re: Fix for vulnerability
Post by lrnnetops »
Hi Team,
Please can you check & suggest a fix on our query.
I am not familiar with what this vulnerability is.
If after you upgrade you can reproduce the upgrade, please submit demonstaration on how to reproduce this to security at nagios.com
