Force check and passive service
steph007
Post by steph007 »
I have seen this post with answer that do not satisfy me:
https://support.nagios.com/forum/viewto ... =7&t=24224
Since the post is old, maybe there is real solution now.
I have the exact same issue.
When my Unxi team fix multiple problems on multiple Hosts, they use the force check on all services to force a check to make sure that they did fix the problem. But passive service with Freshness become in Warning at that moment saying (because my check_dummy set that to warning). Is it possible to avoid such situation? Is is possible to tell Nagios to not force a check on passive?
cdienger
Re: Force check and passive service
Post by cdienger »
This behavior is still the same. Instead of forcing all the checks with the single link, the active services could be forced automatically via the UI or using external commands(https://assets.nagios.com/downloads/nag ... and_id=129) to work around it.
