Whats the difference between monitor physical and vm guest..
Using network switch/router wizard to monitor a Hyper-V guest NIC bandwidth but got 0Gbps? is there a different configuration from physical NIC?
Re: Whats the difference between monitor physical and vm gue
Are you seeing 0Gbps on the graphs or elsewhere? What if you run the check from the command line? It could be a rounding issue if there isn't a lot of traffic on the interface - Try changing the unit from G to B for $ARG4$ on the service and use the "Run Check Command" button to test it.
