How to export Status Map to a generic File
rgomez
Post by rgomez »
Good morning dear..
I would like to know if there is the possibility of being able to export to a common format to be able to visualize the map of the state of the network.
I need to obtain in a file how I have configured the network status map (parent host and dependencies) to be able to broadcast with people who do not have access to my Nagios system.
Of course, I will be grateful to anyone who can help me with this topic.
I take this opportunity to greet them.
Thank you.
Re: How to export Status Map to a generic File
Unfortunately there is no built-in way to do this, the best way that I can think of would be to take a screen capture with a tool such as the Snipping Tool built in to Windows.
rgomez
Post by rgomez »
Thanks you SCOTTWILKERSON for your help..
Regards.
rgomez wrote:Thanks you SCOTTWILKERSON for your help..
Regards.
Glad to be of any assistance I can.
