Hi
I have noticed that in certain accessions snmptt stops processing traps
all services seems to be up when this occurs. that includes snmptt, snmptrapd
the temporary fix is to restart snmptt.
SNMPTT Stops processing traps
Re: SNMPTT Stops processing traps
Can you try implementing this change and test?
https://support.nagios.com/forum/viewtopic.php?p=268562#p268562Re: SNMPTT Stops processing traps
I replaced the script. I'll see how it goes today.
The script that I uploaded to that other post did not have all of the changes done to it so use this one from this post.
Hi
I think it worked. Thanks. I think that resolved the issue. You can close the ticket
