NNA and pnp4nagios
NNA and pnp4nagios
Is NNA compatible with pnp4nagios? ive set up grafana to work with pnp4nagios on my nagios boxes, and I want to see if I can get it (grafana) working with NNA as well.
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Re: NNA and pnp4nagios
pnp4nagios is an addon for Nagios Core, there isn't any way to make it grab data in Network Analyzer unfortunately.
ok thanks you can lock it up!
Proudly running:
Nagios Fusion
Nagios Fusion
Lockingbenhank wrote:ok thanks you can lock it up!
