Graph gadgets
dhoskinson
Graph gadgets
Post by dhoskinson »
I have setup a new check to check the number of processes running on a application server. Currently the number of processes is 750. The performance graph shows 750 just fine but the speedometer only goes to 100. I have been searching for a way to customize that. Our max processes is much higher then that. I know its only a fancy way to show it, but would be nice if it reflected correctly
Re: Graph gadgets
dhoskinson wrote:The performance graph shows 750 just fine but the speedometer only goes to 100
Is this Nagios XI? This question was posted in the Nagios Core forum and there aren't "speedometers" in Nagios Core by default.
dhoskinson
Re: Graph gadgets
Yes it is, i wasn't thinking when i posted it. sorry
Re: Graph gadgets
Can you show the output of the performance data on the advanced tab for this service
